WaF Bot Posté(e) Juin 13, 2020 Signaler Partager Posté(e) Juin 13, 2020 Colorlcd radios Fix missing 0 in date format In mixer screen, display output name in bottom bar if available Text viewer is now displaying one more line Fix 2x1 layout that was allowing two widget in the same location Fix issue in model selector when some bitmaps are missing in SD card Add ES and PT special characters Battery icon has been reviewed and support charge icon on relevant radios Gauge widget text vertical centerinig as been improved Fix an issue where change UID where not displayed until ENTER was pushed Model selection now selects the current category/model on entering Secure display buffer access from lua (fixes crashes from yaapu telemetry) B&W radios Fix an issue on 128x64 when exiting Gvar menu Fix an issue on 128x64 where it was possible to get Edit on logical switch page index Fix several 9XR Pro issues (navigation, extra module,..) Fix switching between channel and mixer monitor on XLite FrSky RAS is now displayed for the right module Some OTA fixes on Horus Add X7 Access simu to Mac companion Add VFR Powers are now displayed in mW rather than dB Multimodule Support for alphabetical protocol ordering Support for FrSky 2.1 ACCST protocols Support for TX clone mode Support for HoTT telemetry Add multi channel naming utility to tools LUA Add units definition to LUA (UNIT_VOLTS,...) for B&W radios Use the right precision for unknown sensor Add table library to colorlcd radios Fix BattCheck taking too much CPU Add EVT_EXIT_BREAK to colorlcd radios Add serialRead function Companion Fix an issue where sensors would be affected by import into Companion Fix an issue where telemetry simulator would not work on sensors discovered on radio itself Add option to prompt for profile on opening (Thx elecpower) Add option for current user/all user install (Thx pre-martin) Improvement in copy/paste/move feature (Thx elecpower) Allow alphanumerical ownerID Add ml/min unit support Fix Cels unit Fix custom failsafe display when 2 modules are enabled in custom mode Fix missing Haptic settings for some radios Add version for Add/remove programs on Windows Miscelaneous Fix issue where switch/flightmode wav play could be broken with long model/flightmode name Jumper T12: fix DMA conflict between SD and internal module Jumper T12: fix an issue with curve edition in mixer screen Jumper T12 Pro: allow multi trainer Fixes in Spanish, Italian, French and Japaneese languages (thx translators !) Fixes issue on curve edit when using rotary encoder INTERNAL_MODULE_PPM option has been fixed, and removed from Companion Fix overflow on flight mode change with large mixer weights Fix flight mode wavs not playing when the mode name was too long Increase Bluetooth buffer length for fast telemetry (fixes crash with 400k crossfire telemetry mirror) Lire la source Lien vers le commentaire Partager sur d’autres sites More sharing options...
Attafr Posté(e) Juin 14, 2020 Signaler Partager Posté(e) Juin 14, 2020 (modifié) Attention, attendez avant de mettre à jour!!! sur le forum français des radio FrSky : Nous allons sans doute devoir sortir une 2.3.9 très rapidement à cause d’un bug lié à la fonction de slow, il vaut mieux attendre ! https://frskytaranis.forumactif.org/t10698-opentx-2-3-8#116148 Modifié (le) Juin 14, 2020 par Attafr Lien vers le commentaire Partager sur d’autres sites More sharing options...
