WaF Bot Posté(e) Janvier 8, 2021 Signaler Partager Posté(e) Janvier 8, 2021 "BETTER_USB_HS" driver A while ago, Microsoft / ST.com introduced though Windows update a change to the handling of their driver which affected OpenTX users trying to use their radio a USB joystick. Based on a suggestion from Joel Stewart here, we have applied for, and gained access to, a unique 'usb id', so starting with 2.3.11, OpenTX users won't be affected by this issue anymore. Backlight function Backlight function has been reviewed and works as below If NO source is selected: The radio behaves as usual if the backlight function is not active backlight will turn on at 'on' brightness when function is active, regardless of radio backlight setting and state this is comparable to legacy backlight function If a source is selected and backlight mode is set to OFF: backlight is set to off level (but not turned off) when the function is not active if backlight function is active and a source is selected, backlight is set to that source level (including screen off if set at -1024) If a source is selected and backlight mode is not set to OFF: The radio behaves as usual if the backlight function is not active if backlight function is active and a source is selected, backlight 'on level' is set to that source level (including screen off if set at -1024). This level is active only when the conditions for backlight to be on are satisfied. Colorlcd radios Fix broken curve display introduced in 2.3.10 Add 4 + 2 modular layout Allow use of R9M2019 in Access mode (requires hardware mod : https://github.com/opentx/opentx/wiki/Externalaccessmod) Fix a ghost row in module setup when using R9M Display output value in top bar of output screen Display log recording symbol on top bar while logging is enabled B&W radios Always display output name if existing in mixer screen LUA Fix insertMix Add getColor function Add resetSensor function Multimodule Allow flashing non-inv firmware on external multi When possible, always use data coming from module (names, ...) Fix AVR module flashing on Taranis Fix telemetry issue when setting up model and having selected CRSF or Ghost protocols FrSky Improve external ports handling to prevent module being powered by serial port when module is OFF Fix XJT Lite telemetry Fix a reboot issue when trying to select SBUS master/serial Miscelaneous Crosstrims: fix trims => subtrim and center beeps Support for Ghost menu displayed on radio screen Allow flashing of ELRS modules Several fixes for AFHDS3 modules Add PPM center handling to Ghost Fix reboot when switching model with "sbus trainer" to model with MULTI or sbus external Fixes text based sensors (flight modes for exemple) Improve Spanish translations Companion Add Mac OS bundle identifier Add S.Port power support Fix print telemetry sensor Improve radio switch setup to better match radio capabilities Fix custom curve handling Improve Spanish translations Fix failsafe settings special function handling Many structural improvements by Elecpower French translations by LapinFou Lire la source Lien vers le commentaire Partager sur d’autres sites More sharing options...
