WaF Bot Posté(e) Juin 14, 2021 Signaler Partager Posté(e) Juin 14, 2021 Colorlcd radios Add GUI for more slider/pots calibration Fix some minor font glitches Add a Quad wizard Improve readability of switch warning when multiple switches are involved B&W radios Some italian fixes Allow shortening of file names in SD manager Increase popup size on small screen LUA Send 0 with LUA getRSSI() when no telemetry is streaming Add getAvailableMemory() Multimodule Always prioritize protocol data coming directly from the module Add support for SX1276 power indication Support for M-Link telemetry Fix per channel failsafe Add support for module config (to allow two multimodule to use the same ID for example) Update data tables to 1.3.2.84 (thanks MRC3742) FrSky add SI support to X9D 2019 add support for FPORT2 add support for race mode Miscelaneous 6POS position are now autodetected when setting up switches source Support for ImmersionRC Ghost GPS sensor Improve switching between modules using different modules Fix Ghost channel range UI glitch Companion A lot of improvement by Elecpower (tons of thanks to him) Fix trainer mode handling for some radios Align RSSI alarm range with radios Fix script max name length Support for 1S radio battery French translation updates (Thx LapinFou) Japanese translation updates (Thx ToshihiroMakuuchi) Lire la source Lien vers le commentaire Partager sur d’autres sites More sharing options...
