OpenTX 2.3.5
WaF Bot
Radio Bugfixes
  • ⚠️Horus / XLitePro: temporary loss of control when an XJT module is used at the same time as an R9M
  • ⚠️Horus / T16: issue where parameters are not properly saved in case of emergency reboot
  • B&W radios: fix an issue where only 6 tools could be displayed in RADIO/TOOLS
  • 128x64 radios: fix wrong default value when creating a timer logical switch
  • Color radios: some fixes to darkblue theme
  • X9E: fix SBUS trainer on external module bay
  • X7 Access: fix "invalid board" message when trying to download from companion
  • Multimodule: add FrSky bind options support
  • Multimodule: more consistently prioritize module data first when available
Companion Bugfixes
  • Add internal multi option to T16 simu
  • Grey unavailable 'backup' option for Horus / T16 radios
  • Fix channel shift for X9 LiteS radio
  • Fix T5/T6 buttons not working as other trims
  • Add "Trainer Channels" function support
Lire la source
