Colorlcd radios
  • Fix missing 0 in date format
  • In mixer screen, display output name in bottom bar if available
  • Text viewer is now displaying one more line
  • Fix 2x1 layout that was allowing two widgets in the same location
  • Fix issue in model selector when some bitmaps were missing in SD card
  • Add ES and PT special characters
  • Battery icon has been reviewed and support charge icon on relevant radios
  • Gauge widget text vertical centering improved
  • Fix an issue where change UID were not displayed until ENTER was pushed
  • Model selection now selects the current category/model on entering
  • Secure display buffer access from lua (fixes crashes from yaapu telemetry)
B&W radios
  • Fix an issue on 128x64 when exiting Gvar menu
  • Fix an issue on 128x64 where it was possible to get Edit on logical switch page index
  • Fix several 9XR Pro issues (navigation, extra module,..)
  • Fix switching between channel and mixer monitor on XLite
FrSky
  • RAS now displayed for the right module
  • OTA Firmware update fixes on Horus
  • Add X7 Access simu to Mac companion
  • Add VFR
  • Powers now displayed in mW rather than dB
Multimodule
  • Support for alphabetical protocol ordering
  • Support for FrSky 2.1 ACCST protocols
  • Support for TX clone mode
  • Support for HoTT telemetry
  • Add multi channel naming utility to tools
LUA
  • Add units definition to LUA (UNIT_VOLTS,...) for B&W radios
  • Use the right precision for unknown sensor
  • Add table library to colorlcd radios
  • Fix BattCheck taking too much CPU
  • Add EVT_EXIT_BREAK to colorlcd radios
  • Add serialRead function
Companion
  • Fix an issue where sensors would be affected by import into Companion
  • Fix an issue where telemetry simulator would not work on sensors discovered on radio itself
  • Add option to prompt for profile on opening (Thx elecpower)
  • Add option for current user/all user install (Thx pre-martin)
  • Improvement in copy/paste/move feature (Thx elecpower)
  • Allow alphanumerical ownerID
  • Add ml/min unit support
  • Fix Cels unit
  • Fix custom failsafe display when 2 modules are enabled in custom mode
  • Fix missing Haptic settings for some radios
  • Add version for Add/remove programs on Windows
Miscelaneous
  • Fix issue where switch/flightmode wav play could be broken with long model/flightmode name
  • Jumper T12: fix DMA conflict between SD and internal module
  • Jumper T12: fix an issue with curve edition in mixer screen
  • Jumper T12 Pro: allow multi trainer
  • Fixes in Spanish, Italian, French and Japaneese languages (thx translators !)
  • Fixes issue on curve edit when using the rotary encoder too quickly
  • INTERNAL_MODULE_PPM option has been fixed, and removed from Companion
  • Fix overflow on flight mode change with large mixer weights
  • Fix flight mode wavs not playing when the mode name was too long
  • Increase Bluetooth buffer length for fast telemetry (fixes crash with 400k crossfire telemetry mirror)
Lire la source
