New radios
  • Jumper T16 (all variants, with or without internal MULTI module)
  • Jumper T12 Pro (with internal MULTI module, coming soon to market)
All radios
  • Improve DE, IT (thx Xillius178, robustini)
  • Telemetry sensors discovery automaticaly stops when sensors slots are all used
  • Better version stamping (allow vendor specific versions)
  • External module now off while module selection is being done in model setup
  • Trainer input lines disabled when signal is lost
  • Trainer function can now replace the channels values instead of the sticks positions
  • Switches are bolded in most places when TRUE
  • Do not display RSSI alarms disabled message for MULTI DSM protocols
  • Fix a range test issue where wrong channel bank would be sent (1-8 , 9-16)
Color LCD radios
  • Firmware flash from SD manager (receiver, modules,..) in now using THEMES colors
  • Add key and analogs debug screens
  • Bootloader is now renamed to openTX bootloader
  • Fix display issue in TOOLS when many tools are available
  • Fix screenshot special function sometime not working
  • Rework spectrum analyser display
  • Fix an issue where x1 play track or similar functions where not working at boot
128x64 LCD radios
  • Rework timer display to allow large value been more nicely displayed
FrSky radios
  • Improve channels count handling when changing R9M mode
  • Fix R9MM-OTA firmware upgrade via OTA
  • Fix some values missing in X7 list (Max, ..)
  • Reskin X9D+ 2019 simulator (thx Ceeb182)
  • Support for ACCESS authenticated module upgrade for X10/X10S
  • Add PMU update capability for X10 Express
  • Change X9D+ 2019 boot sequence to ensure consistent bootloader access
Radio protocols
  • MULTI 1.3 advanced support added
  • FrSky script bidirectionnal support (SxR, BF,…)
  • Wireless Trainer capabilities (only on Jumper radio, requires both EXT and INT MULTI)
  • Increase receiver number (up to 63 depending on protocol)
  • Increase max protocol (up to 127)
  • Add ability to disable channel mapping on some protocols
  • Add ability to disable multi telemetry
  • Display module firmware channel order
  • Ability to setup and use new protocol in the module
  • Graupner HoTT RX support with telemetry
  • Complete rework of FlySky telemetry
  • Complete rework of Hitec telemetry
  • Allow flashing AVR and STM32 MULTI from SD manager (bootloader required on MULTI)
  • MULTI module based spectrum analyser
  • Add TRSS and TLQI to measure telemetry signal strengh to MULTI D8/D16 protocols (currently only for external, also for internal in next RC)
  • Fix SBUS channel range on radio and Companion
Companion
  • Simu use the Batt value of batt warning level + 0.5 volts
  • Fix LS editing on cut / paste
  • Improve specials functions editing (insert/deletele/move,…) (thx Elecpower)
  • Improve outputs editing (insert/deletele/move,…) (thx Elecpower)
  • Better handling of readonly files (thx Elecpower)
  • Fix incorrectly labeled X7 extra switches
  • Improve RX number handling
  • Fix wrong channels count for LR12
  • Fix D8 import / export
  • Allow failsafe settings for MULTI
  • Fix an issue not allowing emages for X9D+ 2019
  • Update Japaneese translations (thx ku2works)
  • Update French translations (thx LapinFou)
  • Update German translations (thx SHezinger)
Lua
  • Fix BOOL input corrupted in Create() function of Lua widget
  • Improve virtual events
Lire la source
