EmuFlight
Release note : fix for Dynamic_filter working as default
Happy to announce the long awaited release of EmuFlight 0.3.0! We are very excited to see everyone using and testing this. This release is 0.3.1, but we already have plans for 0.3.X/full release. As such use this at your own risk. However, much testing has been done and we currently feel like this is a fairly stable version and our testers currently know of no major bugs. **If you are using HD DJI please do not arm your quad while plugged into the gui, the quad will arm. This should be a general practice anyhow, but it is one of the things we want to address in 0.3.x
Angle code has been completely reworked going from 0.2.0 to 0.3.x this is a huge improvement for any whoops.
For anyone confused or wondering about any of the new features in this update we do plan on making videos covering all of these new features and helping to share this information in an easier to understand manner.
Imperative
  • EmuFlight 0.3.X requires EmuConfigurator 0.3.2+
  • DJI componets may bypass arming restriction when plugged into Configurator. Do NOT attempt arming with propellers mounted.
  • Flash with full-chip erase.
  • Do not paste entire diffs from older versions or other flightware. Defaults, calculations, and features have changed significantly.
Major Features
Rate Dynamics (genius way to handle stick feel without changing rates or tune).
Preset tunes updated in the Configurator.
Preset tunes display more information and are better overall.
Improvements to the IMUF filter for non-Helio FC.
Improvements to the IMUF filter for Helio FC New IMUF version 225 and 230 (imuf 225 and 230 only work with version 0.3.x and not 0.2.0).
Voltage throttle compensation (similar to BF battery sag compensation).
Angle/Horizon/NFE code completely reworked.
Matrix filter from iNav.
Minor Features
Helio FC have full use of all the regular filters (off by default).
Ability to set the lpf filters per axis.
WitchCraft filter from RaceFlight (lagged moving average filter for dterm).
Smart Dterm Smoothing a way of shrinking dterm when not needed as much.
Configurable turtle mode power, allows you to increase turtle power or decrease it.
Removal of Anti-Gravity, Iterm-Relax, Acro-Trainer, FeedForward, and Absolute Control.
Now possible to set low-pass filters per axis.
Expert mode
If you want to see additional tuning settings you can enable expert mode (right top corner in GUI). Also you can turn ON expert mode permanently in GUI settings.
Code Contributors
Special thanks to the EmuFlight development team for the countless hours they spent on this and all other updates. Loutwice, Andrey, nerdCopter, Jitter (@gretel), Kaiowarez, and QuickFlash.
Big thanks for Loutwice, nerdCopter and Andrey for helping very much with the configurator.
Shout out to Kaiowarez for adding new targets to EmuFlight.
Thanks to Jitter for automating the build process of test releases.
Special thanks to the other developers who helped with this release of EmuFlight, notably: tylercorleone, NFE, MadChiller, DzikuVx, and Marinus.
Thanks to tylercorleone for adding the voltage throttle compensation (its because of him that EmuFlight has this feature and BetaFlight has voltage sag compensation).
Thanks to NFE for helping with some of the angle code from SilverWare!
Thanks to DzikuVx for porting the iNav matrix filter into Emu and for reviewing the Kalman Filter!
Thanks to MadChiller for working on the BrainFPV Radix target!
Thanks to Marinus for helping with some Kalman Filter improvements!
Test Pilots
Big shoutout to our dedicated team of testers. They work relentlessly testing out the latest code that we send them. They are an amazing group of pilots and have helped progress EmuFlight quicker than we ever thought possible. Big thanks to: MadChiller, MrNoizeFPV, Pierre Meunier, Skylion, PJC, 3dracingman, Denovich, NiceCrash, ehitaja, Filthrillz, gcc.quader, kumokraft, TintFPV, Project Mocking Bird, Vitales, White Hat FPV, teklust5401, Dogsock, Juelz and ill bro.
(If I failed to mention your name as a tester let me know and I can add it to this list)
Without the help of all these contributors EmuFlight would not be what it is today! Big round of applause to all who were and are a part of this adventure!
Lire la source
