Colorlcd radios
  • Improve Popups: highlighted choice is now easier to indentify
  • Improve DarkBlue theme
  • Fix SF alignement issues
  • Fix an issue where multimodule spectrum analyser may sometime not start
  • Add flexi theme
  • Add backlight special function
  • Add .frsk file handling to radio without SPORT connector
  • Fix very large timer display on model select screen
  • Fix an issue where some LUA scripts could overflow stack size
B&W radios
  • Fix some model menu issue for 9X
  • Display 9 gvars on 9x
  • Allow telemetry bars to work from max to min
  • Improve default backlight value on some radio
  • Xlite: channel monitor is now accessed with SHIFT + ENTER
  • Fix some channel monitor display issues on X7 and X9liteS
LUA
  • Fix "Path too long" when calling with 37 chars (fixes iNav scripts)
  • Add MIXSRC_MAX handling
  • Add flightmodes handling
Multimodule
  • Recommended multi version for OpenTX 2.3.10 is 1.3.1.69
  • Fix HoTT BCpT scalling
  • Adapt to multi DSM changes
  • Basic Spektrum forward programming handling (colorlcd only)
FrSky
  • Add support for XACT servo telemetry
  • Add support for FPORT2 receiver option
  • Fix some RB3040 sensors
  • Fix PXX upper channel cycle
Miscelaneous
  • Add support for FlySky FRM302 external module
  • Add support for ImmersionRC Ghost external module
  • Fix distance calculated sensor when using feet altitude sensor
  • Display cursor on custom curves
  • Model off check now also checks at model change
  • Fix mixer overflow when using extremely high weight
  • Fix some spanish, italian translation
  • Sensor disabled by FAI mode are now clearly indicating it
  • Instant trim now only applies to default trims
  • Support "trim idle only" with crossed trims
  • CROSSFIRE: add RXNUM handing
  • CROSSFIRE: add ppm center handling
  • TX16S: allow SBUS in on UARTS (need TTL level, non inverted)
  • TX16S: fix issue in keys diag screen
Companion
  • Better handling of radio choice selection at start
  • Do not close update windows when an error is detected
  • Improve switches conversion between radios
  • Improve telemetry sensors context menus
  • Fix curve handling on BW radios
  • T12 : allow internal module edition
  • X7 Access: add R9M 2019 handling
Lire la source
