Colorlcd radios
  • Add GUI for more slider/pots calibration
  • Fix some minor font glitches
  • Add a Quad wizard
  • Improve readability of switch warning when multiple switches are involved
B&W radios
  • Some italian fixes
  • Allow shortening of file names in SD manager
  • Increase popup size on small screen
LUA
  • Send 0 with LUA getRSSI() when no telemetry is streaming
  • Add getAvailableMemory()
Multimodule
  • Always prioritize protocol data coming directly from the module
  • Add support for SX1276 power indication
  • Support for M-Link telemetry
  • Fix per channel failsafe
  • Add support for module config (to allow two multimodule to use the same ID for example)
  • Update data tables to 1.3.2.84 (thanks MRC3742)
FrSky
  • add SI support to X9D 2019
  • add support for FPORT2
  • add support for race mode
Miscelaneous
  • 6POS position are now autodetected when setting up switches source
  • Support for ImmersionRC Ghost GPS sensor
  • Improve switching between modules using different modules
  • Fix Ghost channel range UI glitch
Companion
  • A lot of improvement by Elecpower (tons of thanks to him)
  • Fix trainer mode handling for some radios
  • Align RSSI alarm range with radios
  • Fix script max name length
  • Support for 1S radio battery
  • French translation updates (Thx LapinFou)
  • Japanese translation updates (Thx ToshihiroMakuuchi)
Lire la source
