Pas mal de vidéos commencent à sortir sur cette nouvelle RC avec TBS Tracer en built in dispo en 2 versions:
https://www.team-blacksheep.com/products/prod:tbs_mambo
https://www.team-blacksheep.com/products/prod:ethix_mambo
TBS Mambo FEATURES
  • TBS Tracer built-in
    • CRSF V3 protocol support for lowest latency and most direct response of any remote control available
    • Range of up to 25km / 15mi
    • Built-in antenna for ultimate ruggedness
    • External antenna available as add-on
  • Full size, ball bearing hall sensor gimbals
    • Configurable resistance and tension
    • Adjustable throttle & pitch throw (+/- 10 degrees)
    • Spare spring set included for lower tension
  • Ergonomic shell design with grippy rubber edges
    • 4x 3-position switches
    • 2x potentiometer with center notch
    • 1x 2-position switches
    • 1x momentary button
    • 4x digital trim buttons
  • Perfectly balanced lanyard mount
  • Up to 12 channels supported
  • Parallel 18650 x 2 (not included!) with USB-C 2A charging (2.5 hours for full charge)
  • Speech audio output with audio jack & haptic vibration alert
  • Open Source remote control operating system (FreedomTX, temporary fork of OpenTX)
  • Rocker dial and 3 button menu for super simple navigation
  • High resolution (128*64) black & white LCD screen w/ backlight
  • 100+ model memory with included SD-card
  • TBS Cloud compatible
TBS Mambo SPECIFICATIONS
  • Weight: 565g
  • Battery: 2 x 18650
  • Audio: 1W speaker & 3.5mm headphone jack
  • Display: 3.5” LCD panel (128 x 64)
  • Antenna: Embedded antenna
  • Switches: 4 x 3pos | 1 x 2pos | 1 x Momentary
  • USB-C Port: Battery charging (5V, 2A), Firmware upgrades & Simulator / HID
Les quelques vidéos sorties ce jour:
Perso j'ai précommandé la version Ethix (179 Eur livrée), à suivre...
Le lien du topic TBS Tracer:
Modifié (le) par Virgiik
  • J'aime 3
