XSRF3O
  • Dimension: 36x36x6mm (L x W x H) with 30.5mm mounting holes
  • Weight: 6g
  • Integrate with XSR receiver
  • 1~16 channels from Sbus output
  • 1~8 channels from PWM outputs
  • Port enabled, support telemetry data transmission and more sensors
  • OSD Configuration has been included in Betaflight GUI.
  • Built-in SD slot
  • Built-in F3 STM32F303 CPU
  • Built-in 6-axis sensor MPU6050 (Accelerometer/Gyro)
XSRF3PO
  • Dimension:60x36x6mm (L x W x H) with 30.5mm mounting holes
  • Built-in SD slot
  • Built-in on-board PDB up to 6S integrate with current sensor
XSRF4O
  • 1~6 channels from PWM outputs
  • Built-in SD slot
  • Built-in F4 STM32F405 CPU
  • Built-in 6-axis sensor MPU6000 (Accelerometer/Gyro)
  • Built-in BARO BMP280
XSRF4PO
  • Weight: 14g
  • Built-in SD slot
