betaflight release notesBetaflight 4.3.0 Release Candidate 1
Just in time for Xmas...
This is a release candidate (RC1). It is intended for testing, and some things still need fixing and fine tuning. Please use it with caution and report back any issues at https://github.com/betaflight/betaflight/issues. Thank you.
Make sure you have got the latest version of Betaflight configurator installed before updating your firmware.
To get the best out of the flight performance improvements, please read the Tuning Notes.
If you want to talk about Betaflight, ask configuration questions, or just hang out with fellow pilots, you can do this in our Facebook group.
Betaflight also has a presence in the Slack messaging platform. Register here, and then come join us in Slack. Most developers hang out there, so this is a great place to talk about the things you are tinkering with in Betaflight, or get help with really complicated configuration problems.
Betaflight 4.3 Release Candidate 1 brings the following updates:
Overall a smoother, more precise flight experience with better propwash perfomance 'and' also an easier setup and tuning experience - to release the full potential of Betaflight 4.
4.3 is a significant evolutionary step thanks to a slew of diligently coded and carefully tested updates representing thousands of hours of work from the voluntary development and test team.
Credits:
- Firmware PR management - Mikeller
**- Configurator and Blackbox - Haslinghuis, Limon, Asizon, ctzsnooze, McGiverGim, Mikeller, Blckmn **
- Presets - Limon, Mikeller, ctzsnooze
- Sliders - Haslinghuis, UAVTech/spatzengr, IllusionFPV, Asizon, ctzsnooze
- Looptime, scheduler, DMA, Gyro EXTI, improved logging and OSD efficiency - Steve C Evans, many massive PR's :-)
- Multi dynamic SDFT notch, filters - Karatebrot #10554
- RPM crossfading - Karatebrot #10757
- RC smoothing - ctzsnooze #10629, #10650
- Feedforward jitter reduction - ctzsnooze #10670
- Feedforward smoothing - ctzsnooze - #10164
- Antigravity - ctzsnooze #10163
- Expo on Gyro LPF - IllusionFPV #10239
- Linear and Dynamic mixer options - TylerCorleone, BorisB #10370
- Dynamic idle improvements - ctzsnooze #10294
- Configurator brilliance - Haslinghuis, McGiverGim, Asizon
- LUA Script - klutvott123, kristjanbjarni, codecae
- Feedforward in level and horizon - ctzsnooze #10778
- PT2 and PT2 lowpass filter options - ctzsnooze #10727
- RC Link improvements - TBS #10675, Stepan Dalecky #10801
- default to Actual rates - ctzsnooze #10724
- 4.3 Tuning Notes - ctzsnooze, editing by SupaflyFPV
- Bugfixes - lots of people!
- Keeping everyone and everything on track - blckmn, mikeller
- Encouragement and testing - Brian White, James, SugarK, Cory Ibanez, Tehllama42, SupaflyFPV, UAVTech, QuadMcFly, Limon, bizmar, and so many others : thank you!
Lire la source
