We are happy to bring you the release version of OpenTX 2.3.0RC1, with support for the production version of the FrSky Xlite-Pro, FrSky X9 Lite, FrSky X10 Express, FrSky X9D+2019 and Jumper T12 radios!
New radios
  • X-Lite Pro
  • X9 Lite
  • X10(S) Express
  • X9D+ 2019
  • T12
All radios
  • A new TOOLS screen has been added to radio section. This screen provide a shortcuts to either build in tools, or lua scripts located in /SCRIPTS/TOOLS directory
  • Version screen now allow you to see the options included in your radio firmware
  • Radio logs now logs all switches declared in hardware menu
  • Radio with power button have now adjustment of on/off timing
  • Radio based wizard have been refreshed (Thx LapinFou)
  • When creating a new model, both modules are now defaulted to "OFF"
  • Improve rotary encoder handling on all radios
  • Improve Czeck translations (Thx Jannek)
  • Improve German translation (Thx SHezinger)
  • Improve Italian translations (Thx mzambrini)
  • Improve Japaneese translations (Thx ku2works)
  • Fix GPS distance calculation on some coordinates
  • RTC Voltage monitoring + alarm (thanks to Mike B)
Frsky
  • Latency for existing XJT modules (internal or external) has been significantly improved
  • Support for Neuron lines ESC telemetry
  • Support for .frsk firmware files. Those contains identification of target hardware, preventing flashing wrong device with wrong firmware type errors
  • Add RTC battery status
  • Radio with external antenna have now choices 'per model' or global settings, with associated updated warnings
Taranis
  • Taranis now allow up to 40 sensors (up from 32)
  • Support for additional switches for X7 on PAD400 and PAD401
  • Support for X9D REV4a removed (wasn't compiling since 2.2)
  • 'full size' modules available on small size external bay as an option
  • X9E : prevent timer display overflow on top LCD
  • X9E : fix key diagnostic display
  • X9E : all sliders are now added correctly after EEprom reset
  • 128x64 : fix trims display
  • 128x64 : protect against negative x drawing
Horus
  • Horus now allows up to 60 sensors (up from 32)
  • Support for additional switches and pots for X10 and X12
  • X12S internal GPS data are now used only when a decent positionning has been achieved
  • Remplacement Express internal module supported using Companion 'internalaccess' option
  • Internal module firmware can now be flashed from OpenTX
  • Add screenshot special function
Sky9x
  • Add R9M flex option to Sky9x
  • Support for Sky9X REVA removed (wasn't compiling since 2.2)
  • Fix for PPM2 not properly initialised
Radio protocols
  • ACCESS protocol added
  • Support up to 24 channels on ACCESS modules when using ACCESS protocol
  • Spektrum analyser and power meter on compatible ACCESS modules
  • New registration and bind mechanism for ACCESS devices
  • Support for OTA updates for upcoming compatible hardware
  • Add Crossfire telemetry mirror on serial port
  • Add Crossfire telemetry mirror on bluetooth
  • Add iNav vario sensor to Crossfire
  • Support for module Multiprotocol 1.2.1.51 (Thx MRC3742 and PascalLanger)
  • Disable RxNum checks for D8 protocol
  • Mixer to pulse synchronisation improved
  • Display FlySky volts as signed values (Thx CapnBry)
Lua
  • Fix TIMEHOUR handling on 128x64 screens
  • Telem 1 to (40/60) items added
  • Lua mix scripts outputs added
  • Fix DIY first ID to 0x5100
  • Introduction of virtual navigation keys
  • Added string type to Horus widget
  • global functions scripts do no run anymore if global functions are disabled in model config
  • GPS data now have a delay attribute
  • chdir function added
  • fix 1bit bitmap draw on 128x64 displays
Companion
  • Multimodule, Crossfire and luac options are included by default in all firmware
  • Fix for Negative GVAR precision (Thx Elecpower)
  • Add receiver number to model list (Thx Elecpower)
  • Add Japaneese translation (Thx Ku2works)
  • Improve french translation (Thx LapinFou)
  • Fix Companion wizard
  • Companion now informs when radio are not currently available
Lire la source
