Getting Started 3.0 Documentation
The important stuff
  • Arming must be on AUX1 for safety and feature reasons, having this fixed allows us to maintain small packet sizes and deliver better aux channel options
  • Be sure to flash both the TX and RX.
  • Lua script MUST be updated to elrsV3.lua and is backwards compatible with 2.x. Get it here: Lua
Compatibility
This is a minor version release (new features, targets and bug-fixes only) and is compatible with V3.0.X.
Who should update from V3.0.0?
All users that require LBT (i.e. the EU/CE regulatory domain for 2.4GHz)
New Targets
  • Transmitter Modules
    • EMAX 2.4GHz Nano and 900MHz Nano
    • Radiomaster 2.4GHz Ranger, Ranger Micro and Ranger Nano
  • Receivers
    • BETAFPV 5A AIO with serial ELRS
New Features
  • Customisable TX button actions (for modules that have buttons) #1761
  • Multiple RGB led support (individually assignable to buttons, boot animations and status indication) #1837
  • PWM fan support for TX modules #1760
  • Betaflight passthrough support for ESP32 receivers (BETAFPV SuperD and Happymodel Dual) #1806
  • Add RSSI_2 for true diversity receivers #1876
  • Receiver SPL06 barometer/vario support #1892
  • Add PWM mapping and failsafe setup to PWM receivers #1763
  • Scale the PWM failsafe time with packet rate #1930
  • Support for brushed motor 10kHz duty-cycle mode in PWM settings #1850
Fixes
  • LBT telemetry lost/recovered loop fixed (for EU/CE regions) #1834
  • Better OTX sync, more reliable locking on packet update frequency #1867
  • Fix Foxeer PA RX not being configured when built #1886
  • Fix QuadKopters Nano RX #1922
  • Fix network credentials being lost on first setup then setting passphrase # 1933
  • ... and many, many more
Known Issues
Lire la source
