INAV 6 Horizon Hawk
Hello and welcome to INAV 6 "Horizon Hawk"
Please carefully read all of this document for the best possible experience and safety.
Get in touch with other pilots, share experiences, suggestions and ask for help on:
68747470733a2f2f646973636f72642e636f6d2f6173736574732f66396262396334616632623963333261326335656530303134363631353436642e706e67 INAV Discord Server
68747470733a2f2f75706c6f61642e77696b696d656469612e6f72672f77696b6970656469612f636f6d6d6f6e732f632f63642f46616365626f6f6b5f6c6f676f5f2532387371756172652532392e706e67 INAV Official on Facebook
Tested and suggested hardware can be found here
Important Notes
Upgrading from a previous release
Upgrading from INAV 5 and 5.1
  1. Download and install the new configurator
  2. Save to a file the current diff all from the CLI.
  3. Upgrade to INAV 6 using the Full Erase option in the configurator.
  4. Upload your OSD font of choice from the OSD tab.
  5. Go to the CLI again and paste the above-described contents from the file you previously created and write save , press ENTER.
  6. There are a large number of new, changed, and removed settings. Check carefully that the settings are correct and fix any unrecognized or out-of-range items from the saved configuration.
  7. You should be ready, explore new 5.0 features, and enjoy!
Upgrading from older versions
Please follow the instructions on this page.
Important changes
New AHRS (Attitude & Heading Reference System)
INAV 6.0 includes a big Update to its AHRS for Attitude Estimation, to make sure INAV always knows it's correct attitude relative to the ground. This should once and for all fix the issue, known as "Horizon Drift" and makes any navigation mode as well as self-leveling modes like ANGLE fully reliable and allows much more precise GPS-Navigation. This affects Fixed Wing as well as Multirotor.
The best results are given if the craft is equipped with GPS and in the case of Multirotor also with a compass. But also for pure LOS Crafts that have no GPS on board, the AHI stability is noticeably improved in most situations. To work best with non-GPS Fixed Wings, the Reference Airspeed has to be set according the average cruise speed of the craft.
Beta only: When Updating from INAV 5.1 or older, apply the following settings after loading back your previous DIFF (Any Fixed Wing or Copter):
set imu_acc_ignore_rate = 15
set imu_acc_ignore_slope = 10
set imu_dcm_kp = 2000
set imu_dcm_ki = 50
set imu_dcm_kp_mag = 2000
set imu_dcm_ki_mag = 50
Fixed Wing only:
set imu_inertia_comp_method = ADAPTIVE
Copter only:
set imu_inertia_comp_method = VELNED
For Fixed Wing Craft with no GPS:
set fw_reference_airspeed =
(set this in cm/s. Set this to airspeed at which PIDs were tuned. Usually should be set to cruise airspeed. Also used for coordinated turn calculation if airspeed sensor is not present.)
If you notice any problems, please head to the Discussion Thread here and post your feedback, if possible with DVR and Blackbox log: #8469
HUD Offset change
The operation of osd_horizon_offset has been reversed, to make it more intuitive. If you have a non-zero value for osd_horizon_offset it will need to be inverted. For example osd_horizon_offset = 1 would become osd_horizon_offset = -1. Positive values move the HUD up, and negative values move it down.
The full list of changes is available here
The full list of INAV Configurator changes is available here
What's Changed
New Contributors
Full Changelog: 5.1.0...6.0.0-FP1
Lire la source
  • Motard Geek changed the title to INAV 6 Feature Preview 1
