INAV 5 Ballistic Buzzard
Hello and welcome to INAV 5.1 "Ballistic Buzzard"
Please carefully read all of this document for the best possible experience and safety.
Get in touch with other pilots, share experiences, suggestions and ask for help on:
68747470733a2f2f646973636f72642e636f6d2f6173736574732f66396262396334616632623963333261326335656530303134363631353436642e706e67 INAV Discord Server
68747470733a2f2f75706c6f61642e77696b696d656469612e6f72672f77696b6970656469612f636f6d6d6f6e732f632f63642f46616365626f6f6b5f6c6f676f5f2532387371756172652532392e706e67 INAV Official on Facebook
Please continue to support developers, for free, by checking out the following stores after having clicked on the following links:
68747470733a2f2f6c68332e676f6f676c6575736572636f6e74656e742e636f6d2f546948587955695a32434f6b374f6d636542676f317165524e324150416a574c357155796447632d55334c716b4a62336e3133456859454a3844707a5f4941434e4855 Support us on Banggood
Your contribution from the past month has been very welcome! Thanks!
Tested and suggested hardware can be found here
Important Notes
Config wipe mitigation
INAV 5.1 lowers the probablity of a full config wipe on reboot. Bear in mind, technically it's not a bug. When FC is disconnected during EEPROM write, checksum will not updated and INAV will erase flash on next boot as a safety measure. To prevent this from happening, always wait until INAV fully reboots before disconnecting the flight controller.
Mamba H743 and ZEEZF7 V2 external flash
INAV 5.1 supports 128Mbit W25N01G flash memory that can be found on Mamba H743 and ZEEZF7 V2.
Horizon Drift mitigation
To improve AHI drift on fixed wings, apply following settings via CLI:
For airplanes without a tail (wings, delta, etc)
set imu_acc_ignore_rate = 9
set imu_acc_ignore_slope = 5
set nav_fw_pos_z_p = 35
set nav_fw_pos_z_i = 5
set nav_fw_pos_z_d = 10
set nav_fw_pos_xy_p = 70
set imu_dcm_kp = 1000
set imu_dcm_ki = 0
For airplanes with a tail (dedicated elevator)
set imu_acc_ignore_rate = 7
set imu_acc_ignore_slope = 4
set nav_fw_pos_z_p = 25
set nav_fw_pos_z_d = 7
set nav_fw_pos_xy_p = 55
set imu_dcm_ki = 0
Upgrading from a previous release
Upgrading from INAV 5
  1. Download and install the new configurator
  2. Save to a file the current diff all from the CLI.
  3. Upgrade to INAV 5.1 using the Full Erase option in the configurator.
  4. Upload your OSD font of choice from the OSD tab.
  5. Go to the CLI again and paste the above-described contents from the file you previously created and write save , press ENTER.
  6. You should be ready, explore new 5.1 features, and enjoy!
Upgrading from older versions
Please follow the instructions on this page.
Important changes
New targets
  • SpeedyBee F7 V3
  • AtomRC F405 NAVI
  • iFlight JB F7 Pro
  • iFlight Blitz F7 Pro
CLI
New Settings
  • nav_fw_launch_abort_deadband Launch abort stick deadband in [r/c points], applied after r/c deadband and expo. The Roll/Pitch stick needs to be deflected beyond this deadband to abort the launch.
What's Changed
Full Changelog: 5.0.0...5.1.0
The full list of changes is available here
The full list of INAV Configurator changes is available here
Lire la source
  • Motard Geek changed the title to INAV 5.1 "Ballistic Buzzard"
