WaF Bot Posté(e) Mai 28, 2022 Signaler Posté(e) Mai 28, 2022 Hello and welcome to INAV 5.0 "Ballistic Buzzard" Please carefully read all of this document for the best possible experience and safety. Get in touch with other pilots, share experiences, suggestions and ask for help on: INAV Discord Server INAV Official on Facebook Please continue to support developers, for free, by checking out the following stores after having clicked on the following links: Support us on Banggood Your contribution from the past month has been very welcome! Thanks! Tested and suggested hardware can be found here Important Notes PCA9685 PWM driver no longer supported The I2C PCA9685 servo driver is no longer supported as obsolete and not widely adopted. All PCA9685 setups are advised to upgrade to SBUS output and SBUS to PWM decoders Gyro and Acc alignment settings removed The align_acc and align_gyro settings are removed. Gyro/Acc orientation should always be set with align_board_yaw GPS Glitch Detection The NAV_GPS_GLITCH_DETECTION was removed as not suitable for modern aircraft. There is no user action required Removal of depreciated MSP frames INAV 5 removed the support for the following MSP frames: MSP_IDENT MSP_PID MSP_PID_CONTROLLER MSP_BF_CONFIG MSP_BF_BUILD_INFO MSP_SET_PID_CONTROLLER MSP_SET_PID MSP_SET_BF_CONFIG MSP_CF_SERIAL_CONFIG MSP_SET_CF_SERIAL_CONFIG No user action is required in the case of the INAV Configurator or mwptools (mwp etc.). In the case of 3rd party INAV configuration apps, this change might break the compatibility if the app was using any of those frames. SpeedyBee developers have been notified, other apps have to adjust accordingly. Strict MSP payload length checking In order to help mitigate the "randomly changed settings" bug, strict MSP payload length checking has been implemented. Fixed size MSP frames that do not specify the correct payload size will be rejected. The INAV Configurator and mwptools (mwp etc.) are compliant. In the case of 3rd party INAV configuration / mission planning / monitoring apps, this change might break interoperability if the app was not correctly setting the payload size. SpeedyBee developers have been notified, other apps may have to adjust accordingly. Upgrading from a previous release Upgrading from INAV 4 and 4.1 Download and install the new configurator Save to a file the current diff all from the CLI. Upgrade to INAV 5.0 using the Full Erase option in the configurator. Upload your OSD font of choice from the OSD tab. Go to the CLI again and paste the above-described contents from the file you previously created and write save , press ENTER. There are a large number of new, changed, and removed settings. Check carefully that the settings are correct and fix any unrecognized or out-of-range items from the saved configuration. You should be ready, explore new 5.0 features, and enjoy! Upgrading from older versions Please follow the instructions on this page. Important changes Configurable outputs mode INAV allows changing the function assignment of ALL PWM outputs. Bear in mind, that it's not resource mapping! This function allows assigning all outputs as motors or all outputs as servos. It's driven by CLI output_mode setting AUTO assigns outputs according to the default mapping SERVOS assigns all outputs to servos MOTORS assigns all outputs to motors Improved landing detection Updates landing detection for multirotor and add detection for fixed-wing. Detects when flying and activates landing detection from that point. Multirotor detection was added for non-autonomous landing as well as RTH. Fixed-wing detection is based on velocity, axis rates, and finally absolute movement in roll and pitch (so it probably wouldn't work if stuck in a tree being blown around by the wind). For details see #7270 Add the ability to adjust LED Strip color with RC channel LED hue can be updated with an RC channel. For example, CLI led 7 8,10::H:6 will adjust hue of LED number 7 based on RC channel 6. For details see #7618 An option to not calibrate the gyro during boot This feature allows to arm of INAV aircraft on a boat or any other moving vehicle, as it allows to use of stored gyro calibration value instead of calibrating on every boot. init_gyro_cal If defined to OFF, it will ignore the gyroscope calibration done at each startup. Instead, the gyroscope's last calibration from when you calibrated will be used. It also means you don't have to keep the UAV stationary during a startup. gyro_zero_x gyro X calibration stored gyro_zero_y gyro Y calibration stored gyro_zero_z gyro Z calibration stored WP mission waypoint enforce altitude option Provides an option to force mission waypoint altitude to be achieved before moving on to the next waypoint. If the set altitude hasn't been achieved when the craft arrives at the waypoint it will hold and adjust the altitude as required with a target margin of 100cm. Planes use a spiral loiter whilst changing altitude. The option is set for the whole mission and applicable to basic and timed hold waypoints. For details see #7644 Improved Altitude Hold controller INAV will now use the SQRT controller for Altitude Control on Multirotors. No extra pilot action required. For details see #7845 TBS Sixty9 SA2.1 UART Configuration Adds the vtx_smartaudio_stopbits setting that when set to 1 fixes the TBS Sixty9 SmartAudio 2.1 issues. Rangefinder in Logic Conditions Adds following value as Logic Conditions Operands: AGL_STATUS boolean 1 when AGL can be trusted, 0 when AGL estimate can not be trusted AGL integer Above The Groud Altitude in cm RANGEFINDER_RAW integer raw distance provided by the rangefinder in cm Matek 1G3SE control via IRC Tramp To use the Matek 1G3SE with IRC Tramp. You will need to enter the CLI command set vtx_frequency_group = FREQUENCYGROUP_1G3. You must also make sure that the initial VTx settings in the configuration tab are in a valid range. They are: vtx_band 1 or 2 vtx_channel between 1 and 9 As part of this change. The default VTx band has been changed from 4 to 1. If you are updating, please check that the band is still correct for your setup. For details see #7949 PWM function mapping change for some targets KAKUTEH7, MAMBAF722_2022A and MAMBAH743 have now 4 motor and 4 servo outputs by default. To enable X8 mode, CLI set output_mode=MOTORS command has to be used. New targets Holybro Kakute H7 Mini KAKUTEH7MINI Diatone Mamba F405_2022A MAMBAF405_2022A Diatone Mamba F722_2022A MAMBAF722_2022A Mateksys F411TE MATEKF411TE Mateksys F405TE MATEKF405TE and MATEKF405TE_SD Foxeer F745 AIO FOXEERF745AIO AOCODARCF7DUAL CLI Changed settings Name Values debug_modes New: LANDING servo_protocol Removed: SERVO_DRIVER New Settings Name Description ground_test_mode For developer ground test use. Disables motors, sets heading status = Trusted on FW. Default: FALSE gyro_zero_x Calculated gyro zero calibration of axis X Values: -32768 - 32767 Default: 0 gyro_zero_y Calculated gyro zero calibration of axis Y Values: -32768 - 32767 Default: 0 gyro_zero_z Calculated gyro zero calibration of axis Z Values: -32768 - 32767 Default: 0 init_gyro_cal If defined to 'OFF', it will ignore the gyroscope calibration done at each startup. Instead, the gyroscope last calibration from when you calibrated will be used. It also means you don't have to keep the UAV stationary during a startup. Default: TRUE ins_gravity_cmss Calculated 1G of Acc axis Z to use in INS Values: 0 - 2000 Default: 0.0 nav_fw_auto_disarm_delay Delay before plane disarms when nav_disarm_on_landing is set (ms) Values: 100 - 10000 Default: 2000 nav_wp_enforce_altitude Forces craft to achieve the set WP altitude as well as position before moving to next WP. Position is held and altitude adjusted as required before moving on. Default: FALSE osd_mah_used_precision Number of digits used to display mAh used. Values: 4 - 6 Default: 4 osd_switch_indicator_one_channnel RC Channel to use for OSD switch indicator 1. Default: 5 osd_switch_indicator_one_name Character to use for OSD switch incicator 1. Values: 0 - 5 Default: GEAR osd_switch_indicator_three_channnel RC Channel to use for OSD switch indicator 3. Default: 5 osd_switch_indicator_three_name Character to use for OSD switch incicator 3. Values: 0 - 5 Default: LIGT osd_switch_indicator_two_channnel RC Channel to use for OSD switch indicator 2. Default: 5 osd_switch_indicator_two_name Character to use for OSD switch incicator 2. Values: 0 - 5 Default: CAM osd_switch_indicator_zero_channnel RC Channel to use for OSD switch indicator 0. Default: 5 osd_switch_indicator_zero_name Character to use for OSD switch incicator 0. Values: 0 - 5 Default: FLAP osd_switch_indicators_align_left Align text to left of switch indicators Default: TRUE osd_system_msg_display_time System message display cycle time for multiple messages (milliseconds). Values: 500 - 5000 Default: 1000 output_mode Output function assignment mode. AUTO assigns outputs according to the default mapping, SERVOS assigns all outputs to servos, MOTORS assigns all outputs to motors Default: AUTO vtx_frequency_group VTx Frequency group to use. Frequency groups: FREQUENCYGROUP_5G8: 5.8GHz, FREQUENCYGROUP_2G4: 2.4GHz, FREQUENCYGROUP_1G3: 1.3GHz. Values: 0 - 2 Default: FREQUENCYGROUP_5G8 vtx_smartaudio_stopbits Set stopbit count for serial (TBS Sixty9 SmartAudio 2.1 require value of 1 bit) Values: 1 - 2 Default: 2 vtx_softserial_shortstop Enable the 3x shorter stopbit on softserial. Need for some IRC Tramp VTXes. Default: FALSE Removed Items Name Description align_acc Use align_board_yaw align_gyro Use align_board_yaw Changelist Add FOXEER F745 AIO Target by @giacomo892 in #7764 Update Battery.md by @MrD-RC in #7800 Added some comparative operations to Programming by @MrD-RC in #7803 [fc_core.c] Make use of macro US2S by @JulioCesarMatias in #7777 Fix compilation when USE_SECONDARY_IMU not defined by @mluessi in #7770 Change Power to Square by @JulioCesarMatias in #7727 Mode availability improvements by @breadoven in #7694 Battery cells in logic condition by @kernel-machine in #7814 Add macros to multicopter land detector by @JulioCesarMatias in #7768 [maths.h] Add Macro to convert Celsius to Kelvin by @JulioCesarMatias in #7767 Remove duplicate semicolon by @JulioCesarMatias in #7806 Release 4.1 by @DzikuVx in #7681 Reversible ESC's for rovers: Don't start motor with high throttle in the mid of the stick by @yajo10 in #7714 [cli.c] Fix external Flash Memory by @JulioCesarMatias in #7695 System message variable display time + setting option by @breadoven in #6850 [gyro.c] An option to not calibrate the gyro during boot by @JulioCesarMatias in #7624 WP mission waypoint enforce altitude option by @breadoven in #7644 SpeedyBeeF7 No led strip #7234 by @andreapede in #7753 Crsf power states redo by @OptimusTi in #7811 Docker build script shebang fix and extended usage notes by @krasiyan in #7793 Add ADC3 support on H7 by @dawr68 in #7824 Add support for Omron 2SMPB-02B barometer by @mluessi in #7755 Omnibus F7.md - mention OMNIBUSF7NXT by @MorrisR2 in #7751 [maths.c] Add 2D and 3D Pythagorean functions by @JulioCesarMatias in #7746 Dzikuvx depreciated MSP frames by @DzikuVx in #7854 Update AUTHORS by @MrD-RC in #7848 Add ability to adjust LED Strip color with RC channel by @jeffhendrix in #7618 Drop MSP_CF_SERIAL_CONFIG and MSP_SET_CF_SERIAL_CONFIG frames by @DzikuVx in #7852 Add macros to active box and reset boxes count by @DzikuVx in #7844 Fix ins_gravity_cmss out of range error by @DzikuVx in #7859 [navigation for multirotor] Sqrt Controller for Alt-Hold and improvements by @DzikuVx in #7845 BMI270: Fix acc alignment by @mluessi in #7769 update Cli.md for 4.1/5.0 usage by @stronnag in #7870 [navigation.c] Replace the position estimate check by @JulioCesarMatias in #7698 Nav launch abort improvements by @breadoven in #7642 Landing detection revamp by @breadoven in #7270 apply stricter payload size checks by @stronnag in #7891 Adjust CMS and statistics page layout for HD OSD by @geoffsim in #7871 Blackbox fields selection on GUI by @kernel-machine in #7896 Add support to BMI270 for IFLIGHT BLITZ F722 by @Guidus93 in #7890 Update to the Telemetry.md docs by @DzikuVx in #7903 Remove "USE_NAV" define by @breadoven in #7909 remove NAV_GPS_GLITCH_DETECTION by @stronnag in #7907 Add LANDING debug by @breadoven in #7904 update target hardware platforms for 4.1 by @stronnag in #7912 RTH sanity checking emergency landing fix by @breadoven in #7790 Replace Sqrt Initialization by @JulioCesarMatias in #7925 Add BMI270 to HGLRCF722 by @DzikuVx in #7939 Configurable outputs mode by @DzikuVx in #7928 document use of ninja as build manager by @stronnag in #7942 Update Blackbox.md by @Dope-johnny in #7943 serial: fix compile error when both GPS_UART and SMARTAUDIO_UART are defined by @snaewe in #7911 Hardware Debugging from VSCode and WSL manual by @erstec in #7945 Update Windows 11 - VS Code - WSL2 - Hardware Debugging.md by @erstec in #7946 Update of project files by @erstec in #7951 Ground test mode by @breadoven in #7921 RTH sanity checking safehome fix by @breadoven in #7917 Hardware Debugging in Visual Studio Code and WSL (Method 2) by @Scavanger in #7950 BLE Support by @Scavanger in #7931 Added missing notes by @MrD-RC in #7966 Enable MPU6500 on MambaF722_I2C by @DzikuVx in #7965 Re-fix for up/down arrows of the relative altitude (ESP32 radar) by @OlivierC-FR in #7914 MAMBAF722_2022A target by @DzikuVx in #7968 MAMBAF405_2022A target by @DzikuVx in #7970 Allow Flight Axis stabilization targets from Logic Conditions by @DzikuVx in #7964 Add switch position indicators to the OSD by @MrD-RC in #7734 Add MatekF411TE Target by @MATEKSYS in #7947 Add MatekF405TE and MatekF405TE_SD Targets by @MATEKSYS in #7924 Fixing the missing commands to ESC by @Odin263 in #7733 Add ICM42688p in MatekH743 by @MATEKSYS in #7974 update Telemetry.md by @stronnag in #7978 Update Programming Framework.md by @Jullibach in #7980 Fix for MambaH743 DMA assignment by @DzikuVx in #7989 Fix KakuteH7 DMA ADC/LED Conflict by @DzikuVx in #7990 TMOTORF7V2 BlackBox fix by @erstec in #7955 VTX SoftSerial StopBit Time by @erstec in #7969 Change fallback ESC protocol to Multishot when DSHOT is not available by @DzikuVx in #7977 Docs update by @DzikuVx in #7992 Failsafe RC adjustment bug fix by @breadoven in #7829 Target output mapping update by @DzikuVx in #7993 [DOC] update Development.md building / running unit tests by @stronnag in #7997 Add new target AOCODARCF7DUAL by @dlt2018 in #7994 Matek 1G3SE control via IRC Tramp by @MrD-RC in #7949 ESP32 Radar: Added support for missing OSD unit types by @MrD-RC in #7972 Enhance mAh Used OSD Element by @MrD-RC in #7868 New target JHEMCU GH743AIO / iFlight Beast H7 55A AIO by @dawr68 in #7889 iFlight Beast H7 V2 I2C2 on UART 3 by @ltwin8 in #7962 Dzikuvx add rangefinder to logic conditions by @DzikuVx in #7984 Docs update by @DzikuVx in #8013 Pitot Tube:Add, Move and Rename macros by @JulioCesarMatias in #8011 Drop gyro and acc alignment settings by @DzikuVx in #8016 TBS Sixty9 SA2.1 UART Configuration by @erstec in #7985 Increase Logic Conditions to 64 by @MrD-RC in #8022 Added Fixed Wing TPA Time Constant to in flight adjustments by @MrD-RC in #8023 Update dynamic_gyro_notch_min_hz range by @DzikuVx in #8021 Update VTx.md by @erstec in #8030 Drop PCA9685 support by @DzikuVx in #8032 Added FW level trim to in flight adjustments by @MrD-RC in #8028 Kakute H7 Mini target by @DzikuVx in #8033 Add Pos Control Jerk Limit Macro by @JulioCesarMatias in #8038 Update PG version for logic conditions by @MrD-RC in #8039 [DOC] minor updates to Blackbox.md by @stronnag in #8040 Add detail to airspeed sensor data by @MrD-RC in #8043 New Contributors @yajo10 made their first contribution in #7714 @andreapede made their first contribution in #7753 @krasiyan made their first contribution in #7793 @dawr68 made their first contribution in #7824 @Guidus93 made their first contribution in #7890 @Dope-johnny made their first contribution in #7943 @Odin263 made their first contribution in #7733 @Jullibach made their first contribution in #7980 @dlt2018 made their first contribution in #7994 @ltwin8 made their first contribution in #7962 The full list of changes is available here The full list of INAV Configurator changes is available hereLire la source
