acheter chassis jeno wearefpv
68747470733a2f2f717561646d6575702e636f6d
Hello and welcome to INAV 4.1 "Red Kite"
Please carefully read all of this document for the best possible experience and safety.
Get in touch with other pilots, share experiences, suggestions and ask for help on:
68747470733a2f2f646973636f72642e636f6d2f6173736574732f66396262396334616632623963333261326335656530303134363631353436642e706e67 INAV Discord Server
68747470733a2f2f75706c6f61642e77696b696d656469612e6f72672f77696b6970656469612f636f6d6d6f6e732f632f63642f46616365626f6f6b5f6c6f676f5f2532387371756172652532392e706e67 INAV Official on Facebook
Please continue to support developers, for free, by checking out from the following stores after having clicked on the following links:
68747470733a2f2f6c68332e676f6f676c6575736572636f6e74656e742e636f6d2f546948587955695a32434f6b374f6d636542676f317165524e324150416a574c357155796447632d55334c716b4a62336e3133456859454a3844707a5f4941434e4855 Support us on Banggood
Your contribution from the past month has been very welcome! Thanks!
Tested and suggested hardware can be found here
Important notes
This release is fully supported only with INAV Configurator 4.1. When an older version of Configurator is used, the OSD tab will not work!
Upgrading from a previous release
Upgrading from INAV 4.0
  1. Use INAV Configurator 4.0 CLI to make a diff of the current configuration
  2. Store the diff output
  3. Download INAV Configurator 4.1 and flash INAV 4.1 firmware with FULL CHIP ERASE
  4. Connect with INAV Configurator and restore the diff with the CLI tab
Upgrading from older versions
Please follow the instructions on this page.
Important changes
  1. HDzero OSD canvas mode support
  2. SD card support on Kakute H7 flight controllers
  3. Improved Matrix filter tracks now 3 gyro noise peaks instead of only 1
  4. Lowered Airmode threshold to improve Airmode handling on powerful multirotors
  5. Fixed RTH Sanity Checking
What's Changed
The full list of changes is available here
New Contributors
Lire la source
