Changelog
  • Add ExpressLRS Cloudbuilds support
  • Add Backpack Cloudbuilds support
  • Add localization support #523 (Thanks @L1cardo!)
  • Add erase and force flash as flashing options #526
  • Add crowdin.com integration #528
  • Fetch locales through http requests to the backend server #531
  • Fix i18next types default namespace path #534
  • Fix error after flashing #538
  • Check if the read config is valid before setting type and frequency #533
  • Fix issue with Auto Updater and I18n #541
  • When filtering the Wi-Fi device selection list, examine the lua name as well as the prior target name #517
  • Add type checking to husky pre commit #543
Which file do I need?
  • Windows (8, 10, 11): ExpressLRS-Configurator-Setup-1.6.0.exe
  • Mac OS X (please
    read macOS install notes): ExpressLRS-Configurator-1.6.0.dmg
  • Linux (please read linux install notes):
    • expresslrs-configurator_1.6.0_amd64.deb (Ubuntu, debian)
    • expresslrs-configurator-1.6.0.pacman (Arch)
    • expresslrs-configurator-1.6.0.x86_64.rpm (Red Hat, Fedora, CentOS)
    • flatpak install org.expresslrs.ExpressLRSConfigurator (Flatpak distribution format)
    • expresslrs-configurator-1.6.0.zip (others)
Lire la source
