acheter chassis jeno wearefpv
Changes since 3.3.0
  • Renamed the BETAFPV Lite Radio 3 to BETAFPV Lite Radio 3 Pro #2319
  • Separated Happymodel EP1/EP2 targets to be more obvious #2319
  • Fixed the naming of the Ghost Atto RX target (it's not a TX!) #2319
  • Renamed Radiomaster Zorro to Radiomaster Zorro Internal #2319
  • Added missing 900MHz Happymodel EPW6 receiver #2332
  • Reduced max packet rate for external modules limited to 400kbaud UART to 333Hz (fixes Lua freezing) #2327
  • Add Radiomaster Pocket radio, an alias for the Zorro target #2342
  • Corrected receiver power for LBT firmware #2334
  • Added back the stock bootloader flashing option for STM32 targets #2354
  • Fixed the maximum output power option for Happymodel ES900TX #2359
  • Reimplemented fuzzy_snr using integer arithmetic #2378 #2379
  • Fix LBT fall back mode #2430
  • Optimize and fix broken FM30 target #2413
  • Fix LBT #2438
Getting Started 3.0 Documentation
The important stuff
  • Arming must be on AUX1 for safety and feature reasons, having this fixed allows us to maintain small packet sizes and deliver better aux channel options
  • Be sure to flash both the TX and RX.
  • Lua script MUST be updated to elrsV3.lua and is backwards compatible with 2.x. Firmware get it here: Lua
Compatibility
This is a patch version release bug-fixes only (mostly) and is compatible with V3.X.
Who should update from V3.3.0?
  • LBT users
  • Users with radios that are limited to 400kbaud and Lua freezing at the loading screen
Lire la source
