Changes since 3.3.1
  • Ability to control SX12xx output power when using a DAC controlled PA (#2498)
  • Fix for 10kHz Duty-cycle not going to 0 or 100% on 8285-based PWM receivers (#2496)
  • Fix PWM channel reset on TX/RX serial port config change via LUA (#2486, #2499)
  • Fix GetLastPacketStats() and diversity packet CRC check (#2488, #2491)
New targets supported by this release
  • RadioMaster Bandit series
Getting Started 3.0 Documentation
The important stuff
  • Arming must be on AUX1 for safety and feature reasons, having this fixed allows us to maintain small packet sizes and deliver better aux channel options
  • Be sure to flash both the TX and RX.
  • Lua script MUST be updated to elrsV3.lua and is backwards compatible with 2.x. Firmware get it here: Lua
Compatibility
This is a patch version release bug-fixes only (mostly) and is compatible with V3.X.
Who should update from 3.3.1 or earlier?
  • Users that are using 10kHz duty cycle output
Warning
  • The IMU has been temporarily disabled on TX modules that support it (Radiomaster Ranger, Radiomaster Bandit, Axis Thor). This has been done in order to work around a bug that has yet to be fixed, as described here: ExpressLRS/targets#30. The following features will not be available on IMU-enabled TXs until the bug has been fixed, and the IMU has been re-enabled:
  1. Bump to loan
  2. Auto-reduce RF power when inactive and disarmed
  3. Auto screen on/off
Lire la source
