INAV 7.1 Ferocious Falcon
Hello and welcome to INAV 7.1 "Ferocious Falcon"
Please carefully read all of this document for the best possible experience and safety.
Contact other pilots, share experiences, suggestions and ask for help on:
68747470733a2f2f646973636f72642e636f6d2f6173736574732f66396262396334616632623963333261326335656530303134363631353436642e706e67 INAV Discord Server
68747470733a2f2f75706c6f61642e77696b696d656469612e6f72672f77696b6970656469612f636f6d6d6f6e732f632f63642f46616365626f6f6b5f6c6f676f5f2532387371756172652532392e706e67 INAV Official on Facebook
Important Notes
INAV 7 is the last INAV official release available for F411 based flight controllers. The next milestone, INAV 8 will not be available for F411 boards.
The GPS NMEA protocol is no longer supported. All pilots are required to switch to UBLOX protocol. All modern GPS modules (even as old as from 2015 and earlier) support UBLOX protocol and there is not a single good reason to stick to NMEA nowadays
Make sure to remove props and check your motor and servo outputs before powering your upgraded flight controller with a battery for the first time. The changes to enable flexible motor and servo allocation may change what outputs your configuration uses by default.
Upgrading from a previous release
Upgrading from INAV 7.0
  1. Backup configuration with CLI diff all command
  2. Download and install the new INAV Configurator 7.1
  3. Flash INAV 7.1 WITHOUT Full Chip Erase option
  4. Done
Upgrading from INAV 6 and 6.1
  1. Download and install the new INAV Configurator 7
  2. Save to a file the current diff all from the CLI.
  3. Upgrade to INAV 7 using the Full Erase option in the configurator.
  4. In case of Analog FPV, upload your OSD font of choice from the OSD tab.
  5. Go to the CLI again and paste the above-described contents from the file you previously created and write save , press ENTER.
  6. There are many new, changed, and removed settings. Check carefully that the settings are correct and fix any unrecognized or out-of-range items from the saved configuration.
  7. You should be ready, explore new 7.0 features, and enjoy!
Upgrading from older versions
Please follow the instructions on this page.
Major changes
Fixed wing Autoland with landing pattern
INAV supports advanced automatic landings for fixed wing aircraft from version 7.1. The procedure is based on landings for man-carrying aircraft, so that safe landings at a specific location are possible. Supported are landings at Safehome after "Return to Home" or at a defined LAND waypoint for missions.
See: Fixed Wing Landing.md
Altitude and Heading estimation changes
INAV now relies more heavily on GNSS data for navigation than before. This can provide more security if the Barometer fails, or if the multirotor is suffering from Compass interference. By still allowing it to navigate back to home.
For more details see here
Other changes
Updated ICM426xx filtering
The filtering of the ICM426xx gyros has been updated based on changes made to both Ardupilot and BetaFlight and we expect better performance, when comparing to previous INAV versions.
Custom OSD
Users can now customize their own OSD messages, by way of the Programming Framework. Details
New Fixedwing flight mode
The mode is called Angle Hold. For more details see here
New targets
  • FLYCOLORF7V2
CLI
Changed settings
Name Description
gps_dyn_model Default: AIR_2G GPS navigation model: Pedestrian, Automotive, Air<1g, Air<2g, Air<4g. Default is AIR_2G. Use pedestrian/Automotive with caution, can cause flyaways with fast flying.
New Items
Name Description
ahrs_gps_yaw_weight Arhs gps yaw weight when mag is avaliable, 0 means no gps yaw, 100 means equal weight as compass Values: 0 - 500 Default: 100
nav_fw_land_approach_length Length of the final approach Values: 100 - 100000 Default: 35000
nav_fw_land_final_approach_pitch2throttle_mod Modifier for pitch to throttle ratio at final approach. In Percent. Values: 100 - 400 Default: 100
nav_fw_land_flare_alt Initial altitude of the flare phase Values: 0 - 10000 Default: 150
nav_fw_land_flare_pitch Pitch value for flare phase. In degrees Values: -15 - 45 Default: 8
nav_fw_land_glide_alt Initial altitude of the glide phase Values: 100 - 5000 Default: 200
nav_fw_land_glide_pitch Pitch value for glide phase. In degrees. Values: -15 - 45 Default: 0
nav_fw_land_max_tailwind Max. tailwind (in cm/s) if no landing direction with downwind is available Values: 0 - 3000 Default: 140
nav_fw_launch_land_abort_deadband Launch and landing abort stick deadband in [r/c points], applied after r/c deadband and expo. The Roll/Pitch stick needs to be deflected beyond this deadband to abort the launch or landing. Values: 2 - 250 Default: 100
nav_min_ground_speed Minimum ground speed for navigation flight modes [m/s]. Default 7 m/s. Values: 6 - 50 Default: 7
nav_rth_fs_landing_delay If landing is active on Failsafe and this is above 0. The aircraft will hover or loiter for X seconds before performing the landing. If the battery enters the warning or critical levels, the land will proceed. Default = 0 [seconds] Values: 0 - 1800 Default: 0
tailsitter_orientation_offset Apply a 90 deg pitch offset in sensor aliment for tailsitter flying mode Default: FALSE
Removed Items
Name Description
inav_w_xyz_acc_p
nav_fw_launch_abort_deadband
TL;DR
The list of most important changes is also available in a video form: https://youtu.be/8Q8t_KwlSAQ
Changelist
The full list of changes is available here
The full list of INAV Configurator changes is available here
What's Changed from INAV 7.0
New Contributors
Full Changelog: 7.0.0...7.1.0-RC1
Lire la source
