Changes from 3.4.1
  • Fix WebUI gzip reminder when flashing ESP8285 receivers #2724
  • Improved WiFi with more captive portal junk #2738
  • Fix for ESP8285 RX as TX #2728
  • Fix immediately leaving bind mode if initial rate change pending #2745
  • Flashing progress time increase to 10s for ESP8285 #2750
  • Fix webui config heap allocation on ESP32 #2727
  • Fix YAW channel triggering VTXAdmin #2740
Compatibility
This is a bugfix/patch release and is compatible with earlier 3.x versions.
Who should update from V3.4.1?
  • This release contains no critical fixes requiring a mandatory update.
  • This release does contain quality of life features such as improved WiFi handling.
Lire la source
