Changes since 3.5.0:
Bugfixes
  • Fixed a bug where the BLE joystick mode would cause the TX module to reset after ~25mins #2944
  • Fixed a bug with MAVLink where uplink commands (e.g. mission uploads, param changes, mode changes from the GCS, fly to here, etc.) would sometimes fail, even at high LQ #2963
  • Fixed an issue with MAVLink where ardupilot was being flooded with RC packets on very high packet rates (K1000 and F1000) #2949 and #2931
  • Fixed a bug on Xrossband modules where the LUA was incorrectly showing blank entries in the packet rate selection #2954
  • Fixed a bug that was causing the TX to jump to 1:2 telem ratio on boot (attempting to send queued MSP messages) #2965
  • Fixed a bug with Xrossband modules that caused sporadic link failure when changing packet rates to DK500, then to a LoRa rate #2966
Other fixes
  • Allow CRSF radios that don't provide a module type #2950
Compatibility
This is a bugfix/patch release and is compatible with earlier 3.x versions.
Who should update from V3.5.0?
  • MAVLink users. Writing missions / waypoints etc is greatly improved.
  • Anyone using BLE joystick long periods of time (>20min).
  • All users with dual band hardware.
  • VTx Admin users.
  • TBS Tango 2 users having difficulties loading Lua on V3.5
Lire la source
