acheter chassis jeno wearefpv
Changes since 3.5.1:
Bugfixes
  • Fix Airport communication #2988
  • Fix STM32 flashing options #2997
  • Fix link connection on Lua setting change for Team900 #3014
Other fixes
  • Housekeeping: remove some compiler warnings #2980
  • Removes two unused variable compiler warnings #2986
  • Allow LR1121 single RF path #2998
  • Remove Serial1 MAVLink check; MAVLink is supported on Serial0 only #2979
  • LUA: Hide Protocol2 for receivers with no pin available for Serial2 #2999
  • Change Joystick mode to report as a "joystick" instead of a "gamepad" #3013
Compatibility
This is a bugfix/patch release and is compatible with earlier 3.x versions.
Who should update from V3.5.x?
  • Airport users updating from 3.4
Lire la source
