Slow 'Other Devices'
After the changes in 3.5.5 for jittery channels when Lua running, there was a side effect then the Other Devices menu in the Lua may load very slowly, if at all. To solve this we've made a few changes to the Lua script and also redeveloped the telemetry queueing system.
Confusing 'initrate' behaviour
The previous behaviour with storing the initial packet rate for receivers was a little confusing to users. This has been changed from storing the 'initrate' when the RX loses connection, to when it get's it's first tentative connection.
Value not updating in Lua script
Occasionally when setting a new value in the Lua script it would not be stored and would revert back to the original value.
Changes since 3.5.5:
Features / Improvements
  • Redeveloped telemetry queueing system #3229
  • Store the RXs initrate during connect, not disconnect #3235
  • Allow hardware definition to specify that PWM/serial pins should be Serial by default #3249
Bugfixes
  • Slow Other Devices loading if at all on 3.5.5 #3222
  • Reduce bad/good queries around user pressing ENTER #3230
  • Reduce RAM usage when not using MAVLink or WIFI mode #3238, #3240
  • Fix for flashing the backpack via UART on the S3 when it's not connected to UART0 #3242
Compatibility
This is a bugfix/patch release and is compatible with earlier 3.x versions.
Who should update from V3.5.x?
This update is recommended for everyone, but particularly for:
  • Users having issues seeing their receiver in the Lua script. i.e. Other devices menu entry not showing.
Lire la source
