INAV 9.0.0
Hello and welcome to INAV 9.0.0
Stable Release
This is the stable 9.0.0 release. For a complete list of changes since 8.0.1, please see the 9.0.0 Release Notes Wiki.
⚠️ Important Upgrade Information
Flashing Notes
  • Full chip erase REQUIRED when upgrading from 8.x
  • Back up your configuration with diff all before flashing
  • Review 9.0.0 Release Notes for breaking changes and incompatible settings
Incompatible Settings Changes
The following CLI settings have been renamed or changed in INAV 9.0. When loading an older diff all, these will show errors:
Renamed Settings:
osd_pan_servo_range_decadegrees replaces the name of the old osd_pan_servo_pwm2centideg
Migration Instructions:
  1. Export configuration from 8.x: CLI → diff all → Save to file
  2. Flash 9.0.0 firmware with Full Chip Erase
  3. Review and update your saved diff for any renamed/removed settings
  4. Load edited diff into new CLI
Changes in 9.0.0 (since RC4)
New Features
  • Pitot Sensor Validation: GPS-based pitot sensor validation with automatic fallback to virtual airspeed on sensor failure (#11222)
    • Adds defensive airspeed clamping to prevent division issues
    • Improves safety for fixed-wing aircraft with pitot sensors
  • MSP_REBOOT DFU Mode: Add optional DFU mode parameter to MSP_REBOOT command for entering bootloader (#11238)
    • Adds payload size validation for command safety
Bug Fixes
  • Blackbox: Fix MOTORS condition mismatch causing null byte padding in logs (#11220)
  • APA (Airspeed Pitch Assist): Improve safety by reducing I-term scaling and maximum gain limits
  • Airspeed TPA: Adjust TPA parameters for better fixed-wing aircraft performance
  • Documentation: Fix Settings.md documentation to match settings.yaml definitions
Target Changes
  • VANTAC_RF007: Add new FrSky/Rotorflight Vantac RF007 target with magnetometer support (#11082)
  • RADIOLINKF722: Add W25Q128 flash chip support (#11232)
Documentation
  • Blackbox DEBUG: Improve DEBUG mode documentation (#11239)
  • README: Add prominent configurator download links (#11221)
  • OSD Elements: Update OSD element documentation
Build/CI
  • Nightly Builds: Add maintenance-9.x to nightly build workflow (#11204)
  • MSP Protocol: Deprecate MSP command 8226, add enum parsing improvements (#11185)
Major Changes in 9.0 Since 8.0.1
JavaScript Logic Conditions
Navigation & Flight Control
  • Improved fixed-wing altitude control with two selectable methods
  • Enhanced position estimator Z velocity accuracy
  • Temperature compensation for accelerometers and barometers
  • Improved VTOL tilt-rotor support with servo speed filtering
  • Enhanced magless multicopter yaw estimation
  • Improved fixed-wing flight detection for auto-disarm
  • Airspeed based PID Attenuation (APA)
OSD & Telemetry
  • Rebranded "Vario" as Vertical Speed Indicator
  • Enhanced ADSB aircraft warnings with extended OSD glyphs
  • New vertical digital throttle gauge display
  • Barometer altitude integrated into CRSF telemetry
  • New OSD elements: VERTICAL_SPEED_INDICATOR, ADSB_WARNING, ADSB_INFO, THROTTLE_GAUGE, NAV_MIN_GROUND_SPEED
  • Increased flexibility for fixedwing minimum ground speed settings
  • SmartPort telemetry: Configure sensors for OpenTX widgets and ETHOS dashboards
Maps & Mission Planning
  • Bing Maps replaced with Esri World Imagery (no API key needed)
  • Better imagery quality and reliability
Programming & Logic
  • Programming Framework enables dynamic minimum ground speed adjustment
  • Extended MSP override capability to 32-bit channels
  • Add MSP2_INAV_SET_GVAR command for global variable manipulation
  • Add MSP2_INAV_LOGIC_CONDITIONS_CONFIGURED command for optimized loading
Hardware Support
  • New Targets (32+ additional flight controller targets including):
    • VANTAC_RF007: New FrSky/Rotorflight Vantac RF007 target with magnetometer support
    • OMNIBUSF4V3_ICM: New target variant
    • BLUEBERRYF435WING target added
  • New Sensors:
    • QMC5883P magnetometer driver
    • Puya PY25Q128HA flash chip support (16MB SPI NOR)
Bug Fixes
  • USB MSC (Mass Storage): Fix H743 USB MSC regression, add timeout protection and retry logic for SD card access
  • Power Limiting: Fix power limiting treating 0 (disabled) as less than continuous current
  • CRSF Telemetry: Fix buffer overflow and dashboard sizeof bug
  • Logic Conditions: Guard against increasing max conditions beyond 64
  • Critical Bugs: Fix integer overflow and buffer overrun issues (cppcheck)
  • Mission control waypoint landing functionality fixes
  • Servo mixer overflow issues fixed
  • Fixedwing level pitch trim accuracy improvements
Performance & Improvements
  • Flight counter addition to statistics tracking
  • Airspeed TPA: Add pitch angle aware TPA with airspeed support
  • Raise pitot_lpf_milli_hz default for better pitot performance
Localization
  • Ukrainian language now available
  • Expanded language support across configurator
Build/CI & Development
  • Include cygwin1.dll in Windows SITL artifact (fixes Windows SITL)
  • Add maintenance-9.x to nightly build workflow
  • Add maintenance branch workflow documentation
  • Add release creation guide
Documentation
  • Add Power and Current Limiting documentation
  • Update JavaScript Programming documentation for namespaced syntax
  • Improve DEBUG mode documentation
  • Add prominent configurator download links to README
  • Update OSD element documentation
  • Fix Settings.md documentation to match settings.yaml definitions
  • Update LedStrip.md documentation
Full Changelog: 8.0.1...9.0.0
Wiki Release Notes: https://github.com/iNavFlight/inav/wiki/9.0.0-Release-Notes
Lire la source
