acheter chassis jeno wearefpv
Changes since 3.6.2:
Bugfixes
  • Allows updating backpack firmware via USB on S3 #3496
  • Fix some STM32 builds because of PIO changes #3495
  • Fix SPI clock rate for 80MHz STM32L432 devices #3493
  • Disable PA when disabling TX & RX on ESP8285 #3485
  • Extend VTX Admin disconnect debounce V3 #3460
  • Extend tcpsocket idle timeout V3 #3444
  • Only use the default UART0 for passthrough flashing #3441
  • Fix LR1121 not committing power change when switching band V3 #3431
  • Fix crash in CRSF parser with CRSF packet length 0 - V3 #3430
Other fixes and improvements
  • Disable backpack in wifi and BLE modes V3 #3432
  • Merge master elrs.lua changes #3463
Compatibility
This is a bugfix/patch release and is compatible with earlier 3.x versions.
Who should update from V3.6.2?
These are all backports from bugs found during 4.0.0-RC1 testing and seek to improve stability and performance for users experiencing:
  • Rotorflight Configurator over wifi frequently disconnects before the tab can load
  • Poor wifi / bluetooth connection stability caused by backpack being active when in these modes
  • Telemetry stops updating when used with external telemetry sensors that generate malformed packets connected to the receiver
  • SPI receivers constant connect/disconnect cycles due to VTX Admin on connect
  • Note! elrs.lua from V4.0.0-RC2 (r16) can be used with 3.x as well. The version number has been removed and is compatible with ExpressLRS 2.x, 3.x, and 4.x
Lire la source
