WaF Bot Posté(e) Janvier 26 Signaler Posté(e) Janvier 26 Changes Since RC1 Config upgrade from 3.3.x not properly upgrading PWM channels #3505 Webui missing RFO_HF enabled on LR1121 #3502 Only show "RF Band" in Lua if hardware permits #3501 Fix GPS Lat/Lon parser for coordinates <10° or >99° #3500 Fix S3 USB passthrough flashing backpack #3497 Handle broadcast routing in deliverMessageTo (fix VTXAdmin) #3483 Add missing fields from model export/import file #3482 Fix PPM/CRSF auto detect for RX-as-TX #3481 Fix Gemini 2.4GHz K modes due to FEC buffer initialization #3473 RC3 Fix for PWM receivers not showing the connection page in the Web UI #3467 RC2 Only use the low bit of the extended channels packet for arm status #3461 Extend VTX Admin disconnect debounce #3459 Prevent POWER_VALUES OOB array access #3458 Ensmallen 8266 firmware binary, switch to LittleFS for all #3457 Remove reference to 750us servo mode in webui #3452 Can't bind RX after RX had connection #3450 Set LQ=0 when handset disconnects #3447 Dual band binding happening on wrong rate TX/RX #3446 #3448 Only use the default UART0 for passthrough flashing #3442 Fix broken I2C on 8285 based receivers #3440 Extend TcpMspConnector idle timeout #3437 Proper packet rate config migration for LR1121 #3439 Move from version-labeled lua to just elrs.lua #3436 Wrong feature flags names being used in webui hardware page #3434 Add isArmed as CH14 #3433 Compatibility Not compatible with ExpressLRS 3.x.x, 2.x.x, or 1.x.x. ExpressLRS major versions are not cross compatible therefore this version 4 OTA is incompatible prior versions and will not connect at all (theoretically). Support for STM32-based hardware has been removed, including all R9M hardware, your ExpressLRS PP, and Ghost devices. NDAA Blue can eat our shorts. Fullres packet modes users in 8ch and 12ch mode will find CH9 or CH13 missing, and Arm moved to CH14. See "Optional Arming Method" below. Any custom hardware.json and options.json (set from the webui Options tab) will be lost due to the flash filesystem update, back them up before updating. See "Flash Filesystem Changed". Highlights Automatic Antenna Modes Stop babysitting your receiver antenna modes. Updated RX/TX syncing now automatically select between True Diversity and Gemini mode based on the transmitter setting so you don't have to. If you connect to a single RF chip receiver, the transmitter also automatically steps down from Gemini mode to antenna switch mode. Optional alternative arming method (requires EdgeTX 2.11.0 or higher) The alternative arming method doesn’t use CH5 to communicate the user’s arming request to the TX module leaving CH5 free to use as a regular control channel. Arming is performed by user selected sources, e.g. physical or logical switches, anything EdgeTX offers as a source really. The alternative arming method works for all packet rates and switch modes but is especially useful for the fullres packet rates in connection with PWM receivers. No more “remapping CH5” required to use CH5 as control channel. The optional arming method can be enabled in the EdgeTX Internal/External RF Model Setup menu by changing “Arm using” to “Switch”. Due to this change, fullres modes no longer "skip" CH5. Previously, 8ch and 12ch modes would generate 9ch or 13ch but now generate exactly the number of full resolution channels specified and CH5 is always a full channel. Users may shift CH6+ down by one or use a higher channel count to account for the change. CH14 now carries the 1 bit arming flag in 8ch and 12ch mode. Expanded PWM receiver output offerings You bought the whole servo, use the whole servo, available servo stretch mode now extends the channel input to 500-2500us output Failsafe ranges have been extended to 476-2523 allow you to failsafe wherever you want on the dial DSHOT 3D mode added as an available output option Statistical Adaptive Dynamic Power Instead of fixed SNR values compiled into the firmware, the dynamic power system now statistically models the SNR expected to result in 99%+ LQ and adjusts power to achieve that. This majorly improves dynamic power for LR1121 systems, which in 3.x tend greatly toward full blast output. Now it goes up, up, up, for a moment... but you're gonna be, gonna be golden. New WebUI New modern WebUI with an updated look and beautiful organized code instead of a pile of javascript that didn’t even have any consistent whitespace. Improved telemetry bandwidth Double telemetry bandwidth when operating in Gemini mode. We're putting eggs in every basket now. Instead of redundant packets, the telemetry downlink now sends data across both Gemini packets, doubling the telemetry bandwidth. All my single ladies aren't left out either. OTA rejiggering means improved telemetry bandwidth for all non-Fullres packet modes too. Std telemetry rate on 500Hz shows a 30% increase in bandwidth, reducing the time to receive 14 Betaflight telemetry items from 6.6s to 5.1s. Combined with the Gemini telemetry change, this provides 66% additional improvement, from 5.1s to 3.1s. Headtracking tracking more than heads Headtracking through the backpack now supports sending the data to EdgeTX instead, and an arbitrary number of channels. Designed for wireless connected pedals (available now) and built in wireless trainer mode (future). New DJI output protocol Slap that DJI Air Unit out of low power mode without needing a flight controller. ExpressLRS now has the ability to arm DJI air units, either tied to arm state or permanently on. New input telemetry protocols supported A NMEA-output GPS can now be attached directly (115200 baud) for sending position, ground speed. Altitude, and satellite count. HoTT telemetry has been extended to support the VSpeak turbine protocol including RPM, fuel level and flow, EGT, ECU voltage, pump and throttle % and status. (Image credit: StartZero100) More robust syncing The OTA now requires a counter synchronization lock to function, ensuring that TX and RX share a consistent state. There were certain cases where you could start a connection, but the Link Quality would stay very low (10-20%) even at close range. Instead of this failed sync going on indefinitely, the connection can no longer progress without proper sync and the RX will automatically retry the connection. Solves the “radio off to check failsafe” issue where sometimes the receiver behaved erratic after re-connect. Making our code less garbagey Core code refactors mean our interface is more CRSF spec compliant, and a new CRSF packet routing system allows data to move data between more than just a handset and flight controller. There's an expanded event flags system and other framework optimizations for the internal device framework that runs peripherals. STM32 support has removed, and our platforms and libraries have been updated to the latest versions. Expanded packet modes for LR1121 The whole reason 4.0 needed to happen! The new sync structure means being able to support more packet modes. LR1121 gets more, up to a staggering 20 packet modes. The Team900, Team2.4, and GemX modes are also no longer mixed in one list and are selectable by band. New modes: K1000 2.4 1000Hz FSK (module baud rate must be 921k or higher) DK250 2.4 250Hz DVDA FSK D50 LoRa 900 50Hz DVDA 25Hz LoRa 900 25Hz LoRa 900 Flash Filesystem Changed The internal flash filesystem has been changed from the deprecated SPIFFS to LittleFS. There is no way to upgrade the filesystem in place. This means custom changes made on the old hardware.html page will be erased during the upgrade, along with items from the Options tab in the webui (receiver baud, airport, wifi and regulatory domain overrides, etc). The hardware.json can be downloaded from the webui before updating and then replaced after updating. PWM mappings and serial protocols are not affected. Minor changes Backpack is now disabled in wifi and BLE modes Wide switch mode is always 6-bit now instead of switching between 6 and 7 bit modes, returning boost telemetry performance back to levels before 3.5.4 TQly telemetry item now samples the last 100 telemetry receives, up from 25 Reduced jitter in receiver serial output by always sending synced with the packet timer instead of at packet reception time. Linkstats are always sent to the handset, even when disconnected. This allows a more immediate notice if the TX believes telemetry has stopped, and in the future we hope this will allow EdgeTX to display more TX status information while disconnected. Lua r16 - Now labeled elrs.lua, contains bugfixes but old r15 or whatever is on your handset is probably fine. Complete List Fix crash in CRSF parser with CRSF packet length 0 #3429 Use invalid CRSF value to differentiate from an actual 0 ChannelData value #3405 Extended pwm failsafe values #3394 HoTT TLM / Support VSpeak turbine protocol #3382 Upgraded Web UI #3381 CRSF handling on the transmitter side #3378 Remove redundant tlmConfirm bit in OTA, increasing tlm bandwidth #3377 Allow arbitrary number of headtrack channels #3373 Change TQly counter to 100 items #3370 Fix DEBUG_INIT not working, unify logger name, simplify some log msgs #3369 Always send LinkStats to handset #3367 Allow secondary CRSF port to send RC data #3364 Atomic channel data updates #3363 Platform upgrade #3341 Statistical Adaptive SNR Thresholds #3302 Wide switch mode always 6 bit, boost to 1:2 #3295 Add OtaNonce to OtaCrcInitializer #3294 CRSF rewrite to be 'more' spec compliant #3198 Dshot 3D mode, allowing for both forward and reverse rotation #3139 Support directly-attached GPS inputs to RX #3086 Mavlink to Ardupilot Custom Telemetry CRSF translation for Yaapu Telemetry Script #3077 Pass HeadTracking Pan/Tilt/Roll back to EdgeTX #3076 Backpack device refactor #3075 Device/event framework optimisation #3049 Communicate Rx available antenna mode to the Tx #3039 Double MSP (TLM and MAVLink) throughput for Gemini hardware #3037 STM32 removal #3033 #3027 #3016 #2960 #2956 Permanently arm DJI (or other MSP displayport) air units using an RX #3028 Adds optional arming method and provides contiguous proportional channels for all full-res modes #3008 Auto configure Rx OTA protocol from the Tx #2994 Auto set True Diversity Rx into Diversity or Gemini mode based on Tx antenna mode #2993 Add tlmConfirm to tlm_dl ota packet-structure #2991 set OtaCrcInitializer to OTA_VERSION_ID during binding #2983 Reduce jitter for CRSF RC packets on the receiver #2943 Disable backpack in wifi and BLE modes #2940 Fix ESP32 based PWM receivers in debug mode #2939 Update OTA_VERSION_ID to V4 #2933 Send RF Mode Enum in place of RF Index in the Sync packet #2932 Split RC data sending from polling and queued data sending V4.0 #2931 Arm DJI O3 directly from an ELRS receiver #2926 Servo stretch feature for wider range servo PWM pulses #2773 D modes for Team900 #2089 Lire la source
