Bonjour j'ai fais l’acquisition d'un Kopis 1 pnp , après avoir trouvé la solution pour bindé un R-xsr (j'ai dut flasher ma taranis en EU(Merci la video de motard-geek)) il ne se passe rien dans l'onglet récepteur de BF.
Si quelqu'un vois le problème
version
# Betaflight / KAKUTEF4V2 (KTV2) 3.2.2 Nov 7 2017 / 15:20:35 () MSP API: 1.36
# name
# resources
# mixer
# servo
# servo mix
# feature
feature LED_STRIP
feature AIRMODE
# beeper
beeper -GYRO_CALIBRATED
beeper -ARMING_GPS_FIX
beeper -BAT_LOW
beeper -RX_SET
beeper -ACC_CALIBRATION
beeper -ACC_CALIBRATION_FAIL
beeper -READY_BEEP
# map
# serial
# led
led 0 4,6::CO:13
led 1 5,6::CO:11
led 2 6,6::CO:12
led 3 7,6::CO:10
led 4 8,6::CO:10
led 5 9,6::CO:12
led 6 10,6::CO:11
led 7 11,6::CO:13
# color
# mode_color
# aux
aux 0 0 0 1700 2100
aux 1 2 1 1700 2100
# adjrange
# rxrange
# vtx
# rxfail
# master
set baro_hardware = NONE
set blackbox_p_ratio = 16
set blackbox_device = SPIFLASH
set dshot_idle_value = 200
set motor_pwm_protocol = DSHOT600
set bat_capacity = 1500
set current_meter = ADC
set osd_vbat_pos = 2081
set osd_rssi_pos = 40
set osd_tim_1_pos = 54
set osd_tim_2_pos = 2104
set osd_flymode_pos = 2529
set osd_throttle_pos = 225
set osd_vtx_channel_pos = 377
set osd_current_pos = 2113
set osd_mah_drawn_pos = 353
set osd_craft_name_pos = 362
set osd_gps_speed_pos = 218
set osd_gps_lon_pos = 82
set osd_gps_lat_pos = 65
set osd_gps_sats_pos = 51
set osd_home_dir_pos = 302
set osd_home_dist_pos = 303
set osd_compass_bar_pos = 266
set osd_altitude_pos = 247
set osd_pid_roll_pos = 423
set osd_pid_pitch_pos = 455
set osd_pid_yaw_pos = 487
set osd_debug_pos = 1
set osd_power_pos = 321
set osd_pidrate_profile_pos = 345
set osd_warnings_pos = 329
set osd_avg_cell_voltage_pos = 76
set osd_pit_ang_pos = 257
set osd_rol_ang_pos = 289
set osd_battery_usage_pos = 392
set osd_disarmed_pos = 138
set osd_nheading_pos = 311
set osd_nvario_pos = 279
set osd_esc_tmp_pos = 82
set osd_esc_rpm_pos = 83
# profile
profile 0
# rateprofile
rateprofile 0
set rc_rate = 155
set yaw_srate = 75
RX serial
sbus
- j'ai également testé ibus
(je sais qu'il y a déja ce genre de post mais je n'ai pas trouvé de solution effective ..)
Salut, est ce qu'on pourrait avoir les photos des branchements que tu as fait entre la fc et le rxsr.
Tant que tu y es, tu as la possibilité d'utiliser la solution du f.port de frsky mais ça nécessite une version spéciale du firmware du rsxr et betaflight 3.3
Je te conseille de tapper dump dans le CLI, copier toute ta config sur un fichier texte, puis de flasher la dernière version de betaflight dispo en écrasant tous les paramètres. Ca permet de repartir sur une base propre si t'as fait des trucs chelous sans le vouloir.
Ensuite soit tu flashes le firmware du site frsky pour utiliser le f.port sur ton rxsr, soit tu réessayes avec le sbus en faisant UNIQUEMENT (ne colle pas ta config sinon tu peux récupérer les erreurs) les manips strictement nécessaires (serial sur le uart 3, serial protocol => sbus...).
Ensuite tu finis de configurer betaflight en collant dans le CLI ce dont tu as besoin.
S'il a réussi à bind le rx je pense que soit sa carte alimente le rx en usb, soit il l'a branché (donc dans tous les cas ça ne change rien normalement).
Selon moi, l'erreur vient sûrement du fait que le sbus soit un protocol inverted. Normalement sur sa carte le uart 3 est déjà inversé, mais s'il a touché au serial port ou qu'il a mal branché un truc ça donne un rx alimenté mais non reconnu.
Alors merci à tous pour vos réponse, il y avait effectivement un probleme dans mes branchements,et surtout il fallait que je reste appuyé 2 sec sur le FS une fois le bind effectué...
Dsl d'avoir remué ciel et terre pour une bidouille pareille mais me voila tout heureux.
Bons vols à vous
