Salut @ tous,
j'ai suivi ce tuto d'Oscarliang concernant le paramétrage d'une alarme "low voltage" sur la taranis, mais la bonne femme me parle tout le temps même quand le quad est désarmé...
J'en profite donc pour ouvrir ce post qui pourrait-être un recueil d'alertes taranis. @Motard Geek est-ce le bon endroit et n'y a-t-il pas déjà un post similaire ?
Je post déjà celle qui ne fonctionne pas à 100% (niveau "alerte de lipo faible" elle fonctionne, mais ne se tait pas lorsque l'on désarme le quad, ou alors se déclenche si on branche l'USB et que la FC alimente le RX):
Citation
L01
a<x   VFAS   14V   L02
This is our primary logical function, it will activate when VFAS (our battery voltage) gets below 14V and when L02 is on (you can set it to any voltage you want, 14V is a good value for 4S LiPo batteries)
L02
a>x   VFAS   0   L03
This switch is used to avoid false alarms when we are just powering on the Taranis TX. When Smart Port is initiating, VFAS will read 0V. This switch is only on when L03 is on.
L03
a>x RSSI 0dB
This switch is also used to avoid false alarms, when Telemetry connection is lost.
L04
Edge   L01   [4.0:<<]
Battery voltage on our mini quad can jump up and down a lot, and the edge switch is there to prevent false alarms caused by voltage fluctuation.
It will only activate when L01 has been activated more than 4 seconds, i.e. it will only turn on when voltage is below 14V for 4 seconds or longer. The switch will not activate when L01 suddenly deactivates before the 4-second is reached, i.e. voltage is recovered above 14V.
L05
a>x   VFAS   14V
This switch is used by the next switch, it simply checks if the battery voltage is recovered above our threshold voltage
L06
Stcky   L04   L05   L07
This is the switch we will use in our Special Function.
The Sticky switch activates when the first parameter is activated (L04) and it turns off when the second parameter is on (L05). This switch stays on or off until the one of the parameters changes state, thus the name “sticky switch”.
L07
Timer   6.0   0,1
Without this timer switch, the voltage warning will only trigger once, if that’s what you want you can simply remove this switch. Using this timer switch, the warning can every 6 seconds (you can change to whatever duration you prefer). Beware this switch is added to the “AND” function of L06.
-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-
To summarize what we have so far… L06 is only activated when the voltage drops below 14V for more than 4 seconds (L04), and L06 is disabled when the voltage rises above 14V (voltage sag recovers or new LiPo attached). The timer switch will ensure the warning is triggered every 6 seconds.
Modifié (le) par toper
