FullSpeed TinyLeader Brushless Whoop 2-3S 25-600mw VTX 1103motor
Un nouveau venu arrive normal ce jour,
Specification:
Brand Name: FullSpeed
Item Name: TinyLeader Brushless Whoop
Weelbase:  75mm plastic + carbon frame (1mm)
Weight: 41g (without battery)
Flight controller: FSD408(F411 FC)  built-in OSD
ESC: FSD408(1-3S ESC)  BLHELI_S 4in1 ESC Dshot600
Motor: 1103 11000KV with connector
Propeller: 40mm 4-blades props, 1.5mm shaft hole
Camera: Caddx Micro F2 camera with angle adjustable(0°- 45°)
VTX: FSD TX600 Pit/25/100/200/400/600 switchable VTX(support IRC Tramp)
FullSpeed FSD408 (F411 FC) Flight controller
Size: 20mm x 20mm x 5mm
Mounting hole: 16mm x 16mm
MCU: STM32 F411
Built-in Betaflight OSD
BEC: 5V/1.5A
FullSpeed FSD408 (1-3S ESC)BLHELI_S 4in1 ESC
Size: 20mm x 25mm x 5mm
Firmware: BLHELI_S
Input voltage: 1-3S
Continuous current: 8
BEC Ouput: NO
FullSpeed FSD TX600 25mW-600mW VTX FPV Transmitter
Output power: PIT/25mW/100mW/200mW/400mW/600mW switchable
Control mode:BFOSD control(support IRC Tramp)/button
Video system: NTSC/PAL
Antenna: IPEX
BAT: 5V Recommended
Frequency: 5.8GHz 6 bands 48 channels, with Raceband: 5362-5945 MHZ
(TX600's factory set up is on lock mode(5733-5866MHZ unlock). Please follow your local laws and regulations
if you need to unlock the frequency.)
Weight: 2.3g
Package Include(BNF include receiver)
1 x TinyLeader frame kit
1 x FSD408 1-3S 8A Flight tower
4 x 1103-11000KV brushless motor with connector
2 x 40mm 4-blade propeller(CW)
2 x 40mm 4-blade propeller(CCW)
1 x Caddx Micro F2
1 x FSD TX600 25mW-600mW VTX FPV Transmitter
DOC ICI
Une version HD aussi avec la Caddx Turtle
TINYLEADER
TINYLEADER HD
J'ai démonté le support de batterie d'origine et installé deux élastiques collé sur une petite mousse par du scotch ; je peux mettre n'importe quelle batterie en 2S ou3S , les batteries résistent à un petit choc et si un des deux élastique lâche il y a l'autre pour finir le vol.
Citation
agréable jouet mais fragile . sur le premier un moteur (AR Gauche ) s'est arrêté au bout d'une semaine ; puis en insistant pour débrider le VTX puis modifier bande , fréquence et puissance avec le bouton , j'ai grillé le VTX et peut-être la carte.
J'ai re- commandé carte + ESC + VTX et tout remonté . Après un jour de vol (6 lipos 2S et 4 3S) des problèmes reviennent :
en 2S il perd de sa puissance au bout de 15 secondes environ puis il culbute sur le dos en plein vol et s'écrase par terre ; avec le 3S ça fonctionne encore bien ...
Ced parle d'un turtle , je n'ai pas ce mode sur le mien.
Avec mon premier j'avais une alarme "rx lost" quand je passais de 2S en 3S le temps d'une lipo ???
Avec le deuxième montage j'ai de nouveau ce message avant qu'il dis-fonctionne .
Bonne réactivité  de FULL SPEED !
je viens de recevoir 3 cartes : la FC , la carte des ESC 4 en 1 et le VTX
je vais remonter le carte des ESC en espérant qu'elle dure plus longtemps que les autres.
Pour info , sur ce post , en début sur la doc du TinyLeader il y a une erreur pour la couleur des leds de réglage du VTX c'est la bleu pour la puissance et la verte pour la bande (au moins pour mes deux premiers VTX).
3 cartes gratuites !!!
