We are happy to bring you the release version of OpenTX 2.2.4
[Companion]
  • Fix negative gvar precision (elecpower)
  • Add mouseover tool tips to label fields with context menus (elecpower)
  • Fix special function Inc/Dec Gvar (elecpower)
  • Better multiprotocol name handling (MRC3742)
  • GPS format matches radio choice (elecpower)
[All radios]
  • Multiprotocol: updated to match 1.2.1.63 (MRC3742)
[All FrSky radios]
  • Fix ModelID unduly checked in D8 mode
  • Support Neuron ESC telemetry
[All radios using Lua]
  • Fix an issue where sportTelemetryPush() was not working when crc is 0x7D or 0x7E
  • Add telem1 to telem32v
  • Add lua mixers outputs
[Horus]
  • Fix plane and glider wizard when no motor is selected
[Taranis]
  • Fix an issue where changing max baud could turn external module on
  • Remove Alt from top bar display in FAI mode
[Sky9X]
  • Add Flex R9M support
[Crossfire]
  • Add support for vario sensor
  • Raw CRSF telemetry data can be mirrored on AUX serial port
Lire la source
