New radios
X-Lite Pro
X9 Lite
X10(S) Express
X9D+ 2019
T12
ACCESS support
Support up to 24 channels on ACCESS modules when using ACCESS protocol
Spektrum analyser and power meter on compatible ACCESS modules
New registration and bind mechanism for ACCESS devices
Support for OTA updates for upcoming compatible hardware
Lua
Fix TIMEHOUR handling on 128x64 screens
Telem 1 to (40/60) items added
Lua mix scripts outputs added
Fix DIY first ID to 0x5100
Introduction of virtual navigation keys
Companion
Fix for Negative GVAR precision (Thx Elecpower)
Add receiver number to model list (Thx Elecpower)
Add Japaneese translation (Thx Ku2works)
Frsky
Latency for existing XJT modules (internal or external) has been significantly improved
Support for Neuron lines ESC telemetry
Support for .frsk firmware files. Those contains identification of target hardware, preventing flashing wrong device with wrong firmware type errors
Due to an FrSky bug in Bluetooth modules, BT radio names have to be in lower case only
Taranis
Taranis now allow up to 40 sensors (up from 32)
Support for additional switches for X7 on PAD400 and PAD401
Support for X9D REV4a removed (wasn't compiling since 2.2)
'full size' modules available on small size external bay as an option
X9E : prevent timer display overflow on top LCD
128x64 : fix trims display
Horus
Horus now allows up to 60 sensors (up from 32)
Support for additional switches and pots for X10 and X12
Screenshots
Sky9x
Add R9M flex option to Sky9x
Support for Sky9X REVA removed (wasn't compiling since 2.2)
Fix for PPM2 not properly initialised
Jumper
Add support for Jumper T12
Radio protocols
Add Crossfire telemetry mirror on serial port
Add iNav vario sensor to Crossfire
Support for Multimodule 1.2.1.51 (Thx MRC3742 and PascalLanger)
Disable RxNUm checks for D8 protocol
Mixer to pulse synchronisation improved
Display FlySky volts as signe values (Thx CapnBry)
Miscellaneous
Improve rotary encoder handling on all radios
Improve Czeck translations (Thx Jannek)
Improve German translation (Thx SHezinger)
Improve Italian translations (Thx mzambrini)
Fix GPS distance callulation on some coordinates
Update to latest multiprotocol revision
RTC Voltage monitoring + alarm (thanks to Mike B)
RADIO / TOOLS menu
Lire la source
