acheter chassis jeno wearefpv
New targets are added to this butterflight fork of EmuFlight. Also some new betaflight features have been added. For more information on the additions see here https://github.com/betaflight/betaflight/releases/tag/3.5.7
set dterm_lowpass_hz = 80
set yaw_lowpass_hz = 0
set buttered_pids = ON
feature -ANTI_GRAVITY
feature OSD
feature AIRMODE
set cpu_overclock = 192MHZ
set gyro_use_32khz = ON
set gyro_filter_q = 2500
set acc_hardware = NONE
set min_throttle = 1080
set motor_pwm_protocol = MULTISHOT
set motor_pwm_rate = 32000
set pid_process_denom = 2
set gyro_sync_denom = 1
set f_pitch = 0
set f_roll = 0
set f_yaw = 0
set tpa_rate = 65
set tpa_breakpoint = 1350
Lire la source
