POUR INFO lien de la lien https://github.com/betaflight/betaflight/releases
Betaflight 3.2.1
mikeller released this 2 days ago · 6 commits to v3.2.x-maintenance since this release
Maintenance Release
Please read the Instructions for Upgrading.
This release contains bugfixes and target changes only. For a full list of new features see 3.2.0.
Fixes:
Configuration does not reset to defaults after an upgrade, and is corrupted instead (#4280);
MavLink port sharing with MSP does not work (#4287);
CRSF Telemetry gets stuck when ACC is turned off (#4279);
Wrong timer assignment for PA14 (#4297);
GD32F350x6 ESCs not supported by 4-way interface (#4329).
When a battery is connected, the ESCs are initialised twice in a row (#4322);
Camera control menu is overlaid with the OSD statistics page if camera control is invoked from the statistics page (#4293);
VTX band colours for LED_STRIP are wrong (#4362);
Dshot beacon sounds when beeper is turning off (#4360);
Dshot ESC info is inconsistent in CLI (#4308);
Dshot1200 timing is wrong for F4 and F7 (#4367);
Stick commands for camera control do not repeat when holding stick (#4368);
Dshot on F7 does not work (#4165);
Toggling WiFi on a RunCam Split will turn it off in flight (#4369);
Arming flag names are not used in CLI in some cases, even if compiled in (#4370).
Target updates:
KIWIF4V2 / PLUMF4: Moved LED_STRIP pin back to VTX.DTA (#4285);
New target: XRACERF4 (#4255).
ALIENFLIGHT: Fixed instable hardware detection issue. (#4300).
BEEBRAIN_V2: Separated into V2D and V2F (#4318).
