This is our sixth release candidate (RC6) for Betaflight 4.3.
Remember some things may need fixing and fine tuning, and there may still be bugs. Please use it with caution and report back any issues at https://github.com/betaflight/betaflight/issues. Thank you!
**Note: Failsafe code has been updated extensively. See: https://github.com/betaflight/betaflight/blob/master/docs/Failsafe.md
IMPORTANT: Make sure you install and use the latest version of the Betaflight Configurator (10.8-RC6 or higher) from https://github.com/betaflight/betaflight-configurator/releases/tag/10.8.0-RC6 before updating your firmware.
To get the best out of the flight performance improvements, please read the Tuning Notes.
If you want to talk about Betaflight, ask configuration questions, or just hang out with fellow pilots, you can do this in our Facebook group.
Betaflight also has a presence on the Discord messaging platform. Come and join us. Most developers hang out there, so this is a great place to talk about the things you are tinkering with in Betaflight, or get help with really complicated configuration problems.
Betaflight 4.3 Release Candidate 6 brings the following updates:
CI Updates:
Updated release.yml (#11525)
Updated stale, no-response and issue templates (#11188)
Fixes:
Removed duplicate line in unit test (#11523)
Widened range of BLHeli/_S device ID (#11513)
Fixed a bug in .bss which uninitialized tasks could not be initialized automatically (#11533)
Fixed GPS rescue failure (#11530)
Fixed no ready beep after GPS was fixed (#11521)
Fixed a bug that caused SPI failures to be repeatedly suspended (#11534)
Fixed OSD visual beeper (#11538)
Fixed failsafe in case of RX sending "failsafe packets" (#11541)
Fixed CRSF baud negotiation (#11500)
Fixed Frsky range check issues (#11536)
Added support for W25X32 flash chip (#11550)
Documentation Updates:
Updated Code of Conduct to 2.1 (#11419)
Corrected spelling, grammar and formatting of modes doc (#11546)
Updated link of fastRorations.pdf (#11476)
Added doc comment requirement to styleguide (#11490)
Configurator:
Presets fix: proper Esc key handling for preset dialogs by @limonspb in (betaflight/betaflight-configurator#2897)
Updated translations by @McGiverGim in (betaflight/betaflight-configurator#2900)
CLI tab: vertical flex fix and removing scroll bars by @limonspb in (betaflight/betaflight-configurator#2903)
Added storybook setup by @chmelevskij in (betaflight/betaflight-configurator#2899)
Made "Activate bootloader" button use bootloader in flash if it exists by @klutvott123 in (betaflight/betaflight-configurator#2904)
Target Updates:
Added missing W25Q128 driver to Unified target, IFLIGHT_H743_AIO and IFLIGHT_H743_V2_AIO (#11537)
Added ICM42605, ICM42688P and LSM6DSO support to NEUTRONRCF411SX1280 target (#11545)
Added EMAXF4SX1280 target (#11540)
Big thanks to:
@SteveCEvans @hydra @haslinghuis @ctzsnooze @bakwc @daleckystepan @klutvott123 @blckmn @mluessi @phobos- @ledvinap @KarateBrot and many more who have tested.
Lire la source
