Introducing: Betaflight 4.4.0-RC5
We are getting very close now Flyers! This will likely be our last Release Candidate. If all goes well, you can expect a full release a week from now.
Out release notes for 4.4.0 are here: https://www.betaflight.com/docs/documentation/Release%20Notes/Betaflight%204.4%20Release%20Notes
Remember that if you are using RC5 of the configurator, there should be no more "red errors" when applying custom defaults and resetting to the "defaults". These defaults are now customised based on the build. There may still be a few items we have missed so any errors that come up please post in the #cloud-build-issues in our Discord or log an issue here.
IMPORTANT: Make sure you install and use the latest version of the Betaflight Configurator (10.9.0-RC5) before updating your firmware.
Please read these important introductory notes:
  1. There is a new betaflight.com website that houses all the documentation and media for helping you get the best out of Betaflight. Well done to the team who have pulled that together. Check it out: http://www.betafight.com.
  2. After updating to Betaflight 4.4.0-RC5, you SHOULD use the latest 10.9.0-RC5 Betaflight Configurator. Earlier configurator versions (e.g.10.8) will not work properly with 4.4 releases. Our preference is you upgrade to the latest RC5 of the configurator as we are close to release.
  3. 4.4 has a new Cloud Building System. This is design to extend the life of smaller flash sized MCUs (F411 and F722) based boards. You need to enable the various options in the build, before selecting "Load Firmware Online" within the configurator. It is super simple, but just be aware that unless you have selected the option for your firmware it will not be available once you flash the board. Don't stress, if you miss an option, just request a new build! 🙂
  4. HD OSD support has been added. This is not currently supported by HD Zero, but some effort there is in the works so watch this space.
  5. Check all your settings carefully before arming for the first time. Check PIDs, Filters, Rates, motor configuration and motor rotation. For the first flights, arm in a safe place, fly gently, and look out for any setup or build issues.
Betaflight has a presence on the Discord messaging platform - and this is the primary location for support, questions and discussions. Come and join us. Most developers hang out there, so this is a great place to talk about the things you are tinkering with in Betaflight, or get help with really complicated configuration problems.
Alternatively, if you don't use Discord and you want to talk about Betaflight, ask configuration questions, or just hang out with fellow pilots, you can do this in our Facebook group.
Betaflight 4.4.0-RC5 brings the following updates:
What's Changed
Improvements
Fixes
Full Changelog: 4.4.0-RC4...4.4.0-RC5
Lire la source
  • Motard Geek changed the title to Betaflight 4.4.0-RC5
