acheter chassis jeno wearefpv
Introducing: Betaflight 4.4.0
Our release notes for 4.4.0 are here: https://betaflight.com/docs/wiki/release/Betaflight%204.4%20Release%20Notes
IMPORTANT: Make sure you install and use the latest version of the Betaflight Configurator (10.9.0) before updating your firmware.
Please read these important introductory notes:
  1. There is a new betaflight.com website that houses all the documentation and media for helping you get the best out of Betaflight. Well done to the team who have pulled that together. Check it out: http://www.betaflight.com.
  2. If your target does not present the 4.4.0 releases in 10.9.0 of the configurator, then please flash 4.3.2 and then submit a support request from within the CLI tab. This should give us enough information to at least get your target up and running with 4.4.0. The reason it will be missing is the manufacturer or our flyers, have yet to provide the details needed about what hardware is on the board.
  3. After updating to Betaflight 4.4.0, you MUST use the latest 10.9.0 Betaflight Configurator. Earlier configurator versions (e.g.10.8) will not work properly with 4.4 releases.
  4. 4.4 has a new Cloud Building System. This is design to extend the life of smaller flash sized MCUs (F411 and F722) based boards. You need to enable the various options in the build, before selecting "Load Firmware Online" within the configurator. It is super simple, but just be aware that unless you have selected the option for your firmware it will not be available once you flash the board. Don't stress, if you miss an option, just request a new build! 🙂
  5. HD OSD support has been added. This is not currently supported by HD Zero, but some effort there is in the works so watch this space.
  6. Check all your settings carefully before arming for the first time. Check PIDs, Filters, Rates, motor configuration and motor rotation. For the first flights, arm in a safe place, fly gently, and look out for any setup or build issues.
Betaflight has a presence on the Discord messaging platform - and this is the primary location for support, questions and discussions. Come and join us. Most developers hang out there, so this is a great place to talk about the things you are tinkering with in Betaflight, or get help with really complicated configuration problems.
Alternatively, if you don't use Discord and you want to talk about Betaflight, ask configuration questions, or just hang out with fellow pilots, you can do this in our Facebook group.
What's Changed
Features
Improvements
Fixes
Targets
Known Issues
  • FIX: Using OSD config when USE_OSD not defined. by @blckmn in #11963
New Contributors
Full Changelog: 4.3.0...4.4.0
Lire la source
  • Motard Geek changed the title to Betaflight 4.4.0
