What's Changed
Improvements
  • Fix unified targets that use OctoSPI. (BF4.4.x) by @hydra in #12307
  • [4.4-maintenance] increase FF smoothing max to suit elrs 1000hz link rate (#12426) by @limonspb in #12433
Fixes
Targets
  • 4.4.1: Patch for config.h files by @blckmn in #12380
  • 4.4.1: Adding support for building by config by @blckmn in #12376
  • [4.4.1] FIX CONFIG: Adding USE_ACC, USE_GYRO and USE_BARO where appropriate. by @blckmn in #12477
  • [4.4.1] FIX CONFIG: Adding USE_FLASH to enable where hardware supports by @blckmn in #12499
Full Changelog: 4.4.0...4.4.1
Lire la source
