acheter chassis jeno wearefpv
ou tu vas dans l'onglet CLI, tu tapes diff, tu valides, tu copies ce que ça t'a affiché, et tu colles ici.
Ok des que je peux, ce soir ou demain !
voila c'est fait
CLI # diff
# Betaflight / IRCFUSIONF3 3.1.7 Apr 6 2017 / 07:23:42 (03f4e40)
feature -VBAT
feature -RX_PARALLEL_PWM
feature RX_SERIAL
feature GPS
feature BLACKBOX
map TAER1234
serial 1 2 115200 38400 0 115200
serial 2 64 115200 57600 0 115200
aux 0 0 2 1000 1400
aux 1 28 0 1700 2100
aux 2 1 0 1300 1700
aux 3 2 0 900 1300
rxrange 0 996 2004
rxrange 1 996 2004
rxrange 2 996 2004
rxrange 3 995 2004
set min_throttle = 1100
set max_throttle = 1900
set min_command = 1015
set small_angle = 180
set serialrx_provider = SPEK2048
set bat_capacity = 1500
set vbat_max_cell_voltage = 40
set vbat_min_cell_voltage = 30
set vbat_warning_cell_voltage = 30
set ibat_scale = 0
set battery_meter_type = EXT
set align_board_yaw = 90
set gyro_sync_denom = 8
set failsafe_delay = 30
set failsafe_off_delay = 0
set failsafe_throttle = 1100
set baro_hardware = AUTO
set pid_process_denom = 1
set blackbox_rate_denom = 2
set blackbox_device = SPIFLASH
profile 0
set gps_pos_p = 0
set gps_posr_p = 0
set gps_posr_i = 0
set gps_posr_d = 0
set gps_nav_p = 0
set gps_nav_i = 0
set gps_nav_d = 0
set setpoint_relax_ratio = 0
set d_setpoint_weight = 0
set yaw_accel_limit = 0.000
set p_pitch = 65
set d_pitch = 50
set p_roll = 55
set i_roll = 42
set d_roll = 40
set p_yaw = 80
set i_yaw = 55
set d_yaw = 15
set p_alt = 55
set i_alt = 55
set p_level = 46
set d_level = 75
set p_vel = 120
set i_vel = 45
set d_vel = 1
rateprofile 0
rateprofile 0
set rc_rate = 70
set rc_rate_yaw = 60
set thr_mid = 0
set roll_srate = 80
set pitch_srate = 80
set yaw_srate = 72
set tpa_rate = 0
  • 1 month later...
Problème résolu, c'était des top radio . Portée trop courte sur spektrum . Je suis passé sur crossfire et fini les problème !
