Déjà debranche les led ça c sur c pas ok
• SBUS: SBUS signal input (the SBUS port has a built-in signal inverter, so if signals need to be inverted,
 please connect the signal wire to this SBUS port. In case signals needn’t be inverted or your receiver has an
 inverter, then please connect the signal wrie to the Rx of UART1/UART3/UART6.)
Donc teste sbus_out sur sbus, si ça marche pas tu mets sur rx1.
