WaF Bot Posté(e) Aout 9, 2019 Signaler Partager Posté(e) Aout 9, 2019 New targets are added to this butterflight fork of EmuFlight. Also some new betaflight features have been added. For more information on the additions see here https://github.com/betaflight/betaflight/releases/tag/3.5.7 set dterm_lowpass_hz = 80 set yaw_lowpass_hz = 0 set buttered_pids = ON feature -ANTI_GRAVITY feature OSD feature AIRMODE set cpu_overclock = 192MHZ set gyro_use_32khz = ON set gyro_filter_q = 2500 set acc_hardware = NONE set min_throttle = 1080 set motor_pwm_protocol = MULTISHOT set motor_pwm_rate = 32000 set pid_process_denom = 2 set gyro_sync_denom = 1 set f_pitch = 0 set f_roll = 0 set f_yaw = 0 set tpa_rate = 65 set tpa_breakpoint = 1350Lire la source Lien vers le commentaire Partager sur d’autres sites More sharing options...
