What's Changed
Fixes
  • Fix read of DPS310 coef C11 by @SteveCEvans in #12011
    4.3 maint SteveCEvans (#12009)
  • Revert b6e2790 as this broke FrSky SPI
  • Refactor USB serial ring buffer code
  • Simplify cliWriter structure definition as use of uint8_t data[] (flexible array member) at the end of the bufWriter_t structure is breaking the F411 build
  • Backup inuntended change impacting F7
  • Raise upper limit of dyn_idle_min_rpm
  • allow dyn_notch_min_Hz as low as 20Hz
  • MSC - Fix MSC on H7. Commit 9629f96, broke MSC. Details on #10747
  • Do not automatically negate CS at end of SPI transfer (cherry picked from commit 92e50d5)
Full Changelog: 4.3.1...4.3.2
Lire la source
