il y a 49 minutes, toper a dit :
@ketshoo tu n'as "que" ça comme perturbations vidéo ?
Oui, c'est pas grand chose mais certains n'ont aucune perturbation avec ce modele.
( désolé Jumnico31 pour le squat de post )
Le 30/12/2017 at 16:10, Qnnk a dit :
Je pense qu'un tuto sur le montage d'un vtx s'impose...
En fouillant le net, j'ai trouvé ça sur le site racedayquads (in English). ça peut déjà aider :) :
SETUP TIPS FOR BEST VIDEO
When setup appropriately, the Bardwell F4 *should* not need any capacitors in order to have clean video. However, on certain setups it will simply be unavoidable. Here are tips on how to setup your board for best video quality and the least likelihood of needing capacitors for perfect video.
The general idea is that you want to limit your camera and VTX's exposure to noise. I.E. - you want to limit exposure to your Bardwell F4, since the noise is produced by your ESCs, then passed through the Flight Controller to your VTX AND your Camera. A common misconception is that noise shows itself only through the VTX, when in fact it can be shown to your video via your Camera. So, here are our tips:
  1. Can your VTX power your Camera? If yes, power your Camera straight off your VTX 100% of the time. If no, then use the supplied camera power pads on the Flight Controller.
  2. If you aren't using it, don't wire it! Not using OSD or camera control? Then wire your camera's video straight to your VTX (not through the video pads on the FC) and do not wire the camera control.
Now, those two general tips will get you darn close! But what if your video still isn't perfect? Here's what you can do further. First, there are two types of issues. One is noise related, one is power related. Noise looks like clear lines through your video. Power issues look like black lines through your video. For a noise problem, a capacitor will work and you can add it now and ignore the tips below and go fly. For those not wanting to add a Cap or those with a power (black lines) issue, keep reading:
  1. I have a noise (clear lines) issue: Follow steps 1 and 2 above. If still noisy (and you don't want to use a cap), then power your camera off of the same pads as your VTX. If this does not work, then your build requires a cap. Kind of a last resort is considering not using OSD or camera control and then wiring appropriately (depends, would you rather no Cap or no OSD in your build?).
  2. I have a power (black lines) issue: Your VTX is power hungry! This is a known thing with some VTXs, like the Mach 2 and the Unify series. They simply do not do well under regulated power. You can often confirm this by testing power levels. The issue will be worse at 800mw than 25mw. The only fix is to power your VTX directly off of the battery leads. If this does not remove the black lines, you have a defective VTX or a defective Camera. We'd bet it's the Camera that has gone bad before the VTX if you are taking a wild guess. But, if all is good then now you should either A) have clear video or B) have noise (clear lines now instead of black). If you have noise, refer to steps 1 and 2 above. If that does not fix the noise, then your build requires a capacitor.
Traduction:
Quand la configuration est faite de manière appropriée, votre FC * ne devrait pas * avoir besoin de condensateur pour avoir une vidéo propre. Cependant, sur certaines configurations, il sera simplement inévitable (certains utilisent 2 condo de 2200uf). Voici des conseils sur la façon de configurer votre carte pour la meilleure qualité vidéo et la moins susceptible d'avoir besoin de condensateurs pour une vidéo parfaite.
L'idée générale est que vous voulez limiter l'exposition de votre caméra et VTX au bruit. C’EST-A-DIRE : vous souhaitez limiter l'exposition de votre FC au bruit, puisque le bruit est produit par vos ESC, puis transmis par le contrôleur de vol à votre VTX ET à votre caméra.
Une idée communément fausse est que le bruit ne se manifeste que dans le VTX, alors qu'en fait il peut très bien être dans votre caméra. Alors, voici nos conseils:
Votre VTX peut-il alimenter votre caméra ? Si oui, alimentez-la TOUT LE TEMPS directement à partir de votre VTX. Si non, utilisez les blocs d'alimentation de caméra fournis sur le contrôleur de vol.
Si vous ne l'utilisez pas, ne le câblez pas ! Vous n'utilisez l’OSD de la FC ou celui de la caméra ? Alors, branchez la vidéo de votre caméra directement sur votre VTX (sans passer par les pads vidéo sur le FC) et ne câblez pas le contrôle de la caméra.
Maintenant, ces deux conseils généraux vous vraiment vous aider ! Mais que se passe-t-il si votre vidéo n'est toujours pas parfaite ? Voici ce que vous pouvez faire pour aller plus loin. Premièrement, il y a deux types de problèmes. L'un est lié au bruit, l'autre est lié à l’alimentation. Le bruit ressemble à des lignes claires à travers votre vidéo. Les problèmes d'alimentation ressemblent à des lignes noires. Pour un problème de bruit, un condensateur fonctionnera et vous pouvez l'ajouter maintenant et ignorer les conseils ci-dessous et aller voler. Pour ceux qui ne veulent pas ajouter un cap ou ceux avec un problème de puissance (lignes noires), continuez à lire:
J'ai un problème de bruit (lignes claires): Suivez les étapes 1 et 2 ci-dessus. Si vous êtes toujours bruyant (et que vous ne voulez pas utiliser de condensateur), alimentez votre caméra à partir des mêmes pads que votre VTX. Si cela ne fonctionne pas, votre build nécessite un cap. Un dernier recours consiste à ne pas utiliser le contrôle de l'OSD ou de la caméra (cf plus haut), puis le câblage de façon appropriée (dépend, préférez-vous pas de Cap ou pas d'OSD dans votre build?).
J'ai un problème de puissance (lignes noires): Votre VTX a besoin de puissance! C'est une chose connue avec certains VTX, comme les séries Mach 2 et Unify. Ils ne fonctionnent tout simplement pas bien sur un régulateur. Vous pouvez souvent confirmer cela en testant les niveaux de puissance. Le problème sera pire à 800mw qu’à 25mw. La seule solution est d'alimenter votre VTX directement sur les fils de la batterie. Si cela ne supprime pas les lignes noires, vous avez un VTX défectueux ou une caméra défectueuse. Nous pourrions parier que c'est la caméra qui a mal tourné avant le VTX. Mais, si tout est bon alors maintenant vous devriez soit A) avoir une vidéo claire ou B) avoir du bruit (lignes claires maintenant au lieu de noir). Si vous avez du bruit, référez-vous aux étapes 1 et 2 ci-dessus. Si cela ne corrige pas le bruit, votre build nécessite un condensateur.
A mon avis, et vu le prix et le poids, un codo devrait être obligatoire sur tout build :)
J'ai donc fait la modif, ma caméra est maintenant alimentée par les 5V du Vtx et ca va beaucoup mieux.
Merci à tous
J'ai une f405 aio matek vendu avec 4 condo que tu soude aux ESC .
L'image est parfaite [emoji7]
Quand je repasse sur l'autre quad sans condo je pleure lol
Envoyé de mon Redmi 3 en utilisant Tapatalk
