Bonsoir
Je viens de monter une Caddx Turbo EOS 2 sur un BetaFpv 75x.
je n'ai plus d'OSD. j'ai essayé de forcer en pal ou NTSC mais ca ne change pas. J'ai désactivé et remis l'OSD mais toujours le meme problème.
J'ai également quelques parasite dans l'affichage dans les lunette. c'est des Machine VRD2.
avez vous une autre piste?
merci a vous 🙂
ca peut surement vous aider. j'ai fait un diff de mes réglages betaflight
Entering CLI Mode, type 'exit' to return, or 'help' # dif
Unknown command, try 'help'
# diff
# version
# Betaflight / OMNIBUSF4SD (OBSD) 3.5.3 Nov 15 2018 / 00:20:01 (61d5abf00) MSP API: 1.40
board_name OMNIBUSF4SD
manufacturer_id
# name
name 75X SE
# resources
# mixer
# servo
# servo mix
# feature
feature -RX_PARALLEL_PWM
feature RX_SERIAL
feature LED_STRIP
# beeper
# beacon
beacon RX_SET
# map
map TAER1234
# serial
serial 0 64 115200 57600 0 115200
serial 5 2048 115200 57600 0 115200
# led
led 0 0,0::A:0
led 1 1,0::A:0
led 2 2,0::L:0
led 3 3,0::L:0
# color
# mode_color
mode_color 6 1 2
# aux
aux 0 0 0 1700 2100 0 0
aux 1 1 1 1300 1700 0 0
aux 2 2 1 1700 2100 0 0
aux 3 28 2 900 1300 0 0
aux 4 35 2 1700 2100 0 0
# adjrange
# rxrange
# vtx
# rxfail
# master
set mag_hardware = NONE
set baro_hardware = NONE
set rssi_channel = 16
set fpv_mix_degrees = 35
set serialrx_provider = SBUS
set blackbox_device = NONE
set dshot_idle_value = 650
set motor_pwm_protocol = DSHOT300
set current_meter = VIRTUAL
set ibatv_scale = 90
set ibatv_offset = 29
set yaw_motors_reversed = ON
set small_angle = 180
set pid_process_denom = 1
set osd_warn_core_temp = OFF
set osd_vbat_pos = 2406
set osd_rssi_pos = 2049
set osd_tim_2_pos = 2552
set osd_flymode_pos = 2521
set osd_throttle_pos = 2401
set osd_crosshairs_pos = 2253
set osd_mah_drawn_pos = 2317
set osd_craft_name_pos = 394
set osd_warnings_pos = 2414
set vtx_power = 2
set vcd_video_system = NTSC
set rcdevice_init_dev_attempts = 4
# profile
profile 0
set dterm_notch_cutoff = 0
set vbat_pid_gain = ON
set anti_gravity_gain = 2000
set iterm_relax = RP
set iterm_limit = 500
set pidsum_limit = 1000
set pidsum_limit_yaw = 1000
set p_pitch = 65
set i_pitch = 80
set d_pitch = 50
set f_pitch = 96
set p_roll = 65
set i_roll = 80
set d_roll = 50
set f_roll = 96
set i_yaw = 75
set f_yaw = 100
# rateprofile
rateprofile 0
Salut
Merci pour ton message.
Non pas encore.
J’ai mis ajout betaflight, j’ai regardé les soudures. Mais aucun changement.
A suivre [emoji30]
Alors moi j'ai réussi, en gros je l'ai connecté a betaflight avec l'accu de branché. Ensuite je suis aller dans l'osd, j'ai modifié l'emplacement des infos directement bsur l'aperçu, enregistrer redémarrer le quad et hop ça à fonctionné pour moi. [emoji1696]
Envoyé de mon ONEPLUS A5010 en utilisant Tapatalk
J ai tellement galèré à résoudre l’EOS2 que je n’ai pas essayé de remettre l’ancienne caméra.
Et tu as encore le vtx d'origine ? Je pense que le fait de déplacé les infos de l'osd sur betaflight permet de réinitialiser le tout il faut bien cliquer sur enregistrer et ensuite redémarrer betaflight et enlevé l'accus et la remettre.
Oui c’est le vtx d’origine.
Oui j ai sauvegardé et fait les manipulations comme toi.
Je vais essayer encore demain.
Alors
Ça matin ça a marché.
J’ai modifié les emplacement de l’affichage dans l’osd dans betaflight.
Et après j’ai cliqué sur sauvegarder et en plus j’ai fait un save dans le cli.
Et là ça marche [emoji108][emoji1]
Cool merci.
  • 2 months later...
Je viens d'installer mon 75x sur la Nano Sr (une merveille cette petite frame) et j'ai profité de l'occasion pour remplacer la caméra de la z02 par une turbo eos 2... Et la c'est le drame, comme vous, j'ai perdu la totalité de mon osd.
Mais votre manipulation n'a pas marché pour moi... Je vous décrit tout pour voir où j'ai raté quelque chose.
1 brancher la lipo
2 brancher l usb et sur betaflight actualisé l'osd par la modification de ce dernier
3 effectuer une save par le cli (à cet instant je n'ai toujours pas l'osd)
4 débrancher l usb
5 débrancher la lipo
6 brancher la lipo (toujours pas d'osd)
MA manipulation est correcte ?
Merci pour votre aide.
Merci Quazardous pour la piste.
C'était déjà en NTSC, du coup je viens de faire un test en Auto, PAL et de nouveau NTSC. Le problème est toujours présent.
Problème résolu.
Pour ma part la config a besoin d'être en PAL.
La manipulation a marché quand j'ai forcé depuis le CLI.
  • 5 months later...
Salut j'ai le même soucis depuis le changement de mon vtx sur le beta 75x c'est quoi la commande du cli pour forcer en pal? Merci
J’avais le même souci, et j’ai uniquement changé le format video dans la page osd de betaflight en pal ( si tu es en ntsc niveau lunette, il faudra choisir ntsc) et j’ai sauvegardé. L’osd is back 😀
  • 5 months later...
cool, idem pour moi j'ai remplacé la cam de mon 75x par une runcam nano 2, plus d'osd > forum wearefpv > drone alimenté, connection sur betaflight, passage en PAL et "save" dans le CLI ça a fonctionné direct, merci 😉
  • 2 months later...
Bonjour
Je viens d'acquérir un drone d'occaz. Zmr450 runcam eagle 2 vtx eachine et FC F3sp racing
J'ai bien l'image mais aucun OSD. Pourtant dans betaflight j'ai coché OSD, j'ai accès à l'onglet et par contre une seule colonne pour cocher les cases.
Je n'ai aucune option pour passer en NTSC ou PAL et la commande cli ne fonctionne pas.
Merci pour votre aide..
il y a 46 minutes, romumu72 a dit :
Bonjour
Je viens d'acquérir un drone d'occaz. Zmr450 runcam eagle 2 vtx eachine et FC F3sparing.
Tu auras beau cocher tout ce qu'il faut dans Betaflight,   certaines anciennes génerations de FC F3sparing ne dispose pas d'un OSD interne dans mes souvenirs... On me confirme ? Merci.
J’en ai bien peur... j’ai regardé les schémas de montage... et apparement pas d’OSD...
va falloir que je m’en passe
Je sais pas si je peux avoir une alerte au moins de batterie faible?
Pas d’osd sur une spracing. Si tu veux une alerte tension, il faut un buzzer avec les alertes sur BF qui sonne quand tu es rentré dans tes valeurs que tu souhaites. Mais il faut également de bonnes oreilles pour entendre le buzzer.
Merci les amis pour votre aide. Le buzzer est déjà configuré... Reste plus qu'à écouter...
